Dvk Posted December 6, 2005 Report Share Posted December 6, 2005 How do I install a high low converter to my stock 95 volvo 850 radio to get rca outputs for my amp? Link to comment Share on other sites More sharing options...
Bing_0 Posted December 6, 2005 Report Share Posted December 6, 2005 a high low converter has an input side and an output side.the in put side has two PAIRS of speaker wires coming out, left and right sdie, each positive and negative wires. waht you do is tape these speaker wires into the stock speaker wiring, left and right, you can do this at either behind the radio, or anywhere in between the radio and the speaker where you can access the stock sepaker wiring, the easier is probably going to be your rear deck speaker if you ahve a sedan, or behind the radio if you have a wagon (the rearpillar speakres on wagons are probably high passed already).anyway, the output side of hte hihg low converter has two RCA outputs, you simply connect an rca cable from here to the amp. and done.some high low converters have a grounding wire, in most cases, dont worry abou thtis wire unless you are getting a lot of engine noise through the speakers your amp is powering, if it does, you can try grounding this wire, but in my experience, it doesnt do that much.enjoyb Link to comment Share on other sites More sharing options...
Dvk Posted December 6, 2005 Author Report Share Posted December 6, 2005 a high low converter has an input side and an output side.the in put side has two PAIRS of speaker wires coming out, left and right sdie, each positive and negative wires. waht you do is tape these speaker wires into the stock speaker wiring, left and right, you can do this at either behind the radio, or anywhere in between the radio and the speaker where you can access the stock sepaker wiring, the easier is probably going to be your rear deck speaker if you ahve a sedan, or behind the radio if you have a wagon (the rearpillar speakres on wagons are probably high passed already).anyway, the output side of hte hihg low converter has two RCA outputs, you simply connect an rca cable from here to the amp. and done.some high low converters have a grounding wire, in most cases, dont worry abou thtis wire unless you are getting a lot of engine noise through the speakers your amp is powering, if it does, you can try grounding this wire, but in my experience, it doesnt do that much.enjoybHow do I know which ones are the speakers wire behind the stereo? Are they labeled or a certain color? and all I do is take the 2 wires together? Link to comment Share on other sites More sharing options...
Slater Posted December 6, 2005 Report Share Posted December 6, 2005 How do I install a high low converter to my stock 95 volvo 850 radio to get rca outputs for my amp?I personally avoid high-low converters if possible. They degrade the signal and cause engine noise.If your stock radio has the AMP plug on it, I make a DIN adapter cable to convert it to 2 pairs of RCAs for you. No high-low converters needed. Just plug the adapter cable into the DIN plug on the back of the cable and run RCAs right to your new AMP. Clean and simple. Link to comment Share on other sites More sharing options...
banksie312 Posted December 6, 2005 Report Share Posted December 6, 2005 i have an amp that i will run for a sub that im getting (soon enough) but i do not want to lose the function of my back passinger speakers, how do i do this?slater can i use your AMP cable? ps its for a v70 Link to comment Share on other sites More sharing options...
Dvk Posted December 6, 2005 Author Report Share Posted December 6, 2005 I personally avoid high-low converters if possible. They degrade the signal and cause engine noise.If your stock radio has the AMP plug on it, I make a DIN adapter cable to convert it to 2 pairs of RCAs for you. No high-low converters needed. Just plug the adapter cable into the DIN plug on the back of the cable and run RCAs right to your new AMP. Clean and simple.Im not too sure if my stock radio have a din plug on it..And if it does where do i get that adapter? Link to comment Share on other sites More sharing options...
the underlørd Posted December 6, 2005 Report Share Posted December 6, 2005 Im not too sure if my stock radio have a din plug on it..And if it does where do i get that adapter?you have the SC-815? Link to comment Share on other sites More sharing options...
Dvk Posted December 6, 2005 Author Report Share Posted December 6, 2005 you have the SC-815?Yes i beleive so on the 95 850Yes i beleive so on the 95 850So what do i need to have rca outputs some kind of adapter?And where can i get one of those fromYes i beleive so on the 95 850So what do i need to have rca outputs some kind of adapter?And where can i get one of those fromAlso is it just as easy as pluging it into where the cd player goes in the back...Which is empty for me Link to comment Share on other sites More sharing options...
Dvk Posted December 6, 2005 Author Report Share Posted December 6, 2005 How do I hook up a high low converter to my stock 850 radio or how do i install a din cable adapter with rca outputs for my amp.WHich is better and how do i install them? Link to comment Share on other sites More sharing options...
Dvk Posted December 6, 2005 Author Report Share Posted December 6, 2005 How do I join the speaker wires from the high lower converter to the stock radio?Do i have to cut the stock wires and soder them together?How do I join the speaker wires from the high lower converter to the stock radio?Do i have to cut the stock wires and soder them together?Can someone please show me a diagram or give me instuctions because im new when it comes to this stuff..I have very little knowledge Link to comment Share on other sites More sharing options...
Dvk Posted December 6, 2005 Author Report Share Posted December 6, 2005 I have a spot that says amp on the back of my stock radio what is that for? Link to comment Share on other sites More sharing options...
AnthonyR Posted December 7, 2005 Report Share Posted December 7, 2005 Both slater and I have made them. I don't have any parts left to make any more, so you might try slater. Also if you go to http://project850.no-ip.org/There are instructions on how to make your own if your decent at soldering.I have a spot that says amp on the back of my stock radio what is that for?That is where you would plug one of those DIN adapters into.How do I hook up a high low converter to my stock 850 radio or how do i install a din cable adapter with rca outputs for my amp.WHich is better and how do i install them?DIN convertor is as cheap as the hi-lo convertor as is very easy. Just plug it into the amp connector and plug your RCA's into it. That way no cutting or finding wires or soldering. And it has loads better sound quality and clarity. Link to comment Share on other sites More sharing options...
