850R Sleeper Posted December 7, 2005 Report Share Posted December 7, 2005 So, I went out a little while ago to run to the store to pick up a few things. I have a remote starter on my 96 854 R and started my car from a distance. I got in and drove to the store no problem. I'm in the store for about fifteen minutes and while leaving to go to another store I decide to start it so it will be warm when I come out...nothing. I walk to my car, get in and try to start it again...nothing. I have a feeling that it might be the alternator, but I'm not sure. Something like this happened last year when my car was draining the battery. Come to find out, the place that installed my dual stage boost controller f'ed up and installed it incorrectly. I don't think it was that again though, because I had it fixed...so...any suggestions? Link to comment Share on other sites More sharing options...
shurgen Posted December 7, 2005 Report Share Posted December 7, 2005 So, I went out a little while ago to run to the store to pick up a few things. I have a remote starter on my 96 854 R and started my car from a distance. I got in and drove to the store no problem. I'm in the store for about fifteen minutes and while leaving to go to another store I decide to start it so it will be warm when I come out...nothing. I walk to my car, get in and try to start it again...nothing. I have a feeling that it might be the alternator, but I'm not sure. Something like this happened last year when my car was draining the battery. Come to find out, the place that installed my dual stage boost controller f'ed up and installed it incorrectly. I don't think it was that again though, because I had it fixed...so...any suggestions?Does the engine spin or battery completely dead?Off topic - if this is your car in your signature, how did you make the hood open up so high? Seems like almost vertical. Link to comment Share on other sites More sharing options...
Guest AlvinL Posted December 7, 2005 Report Share Posted December 7, 2005 Off topic - if this is your car in your signature, how did you make the hood open up so high? Seems like almost vertical.There is a stop on each side hinge that can be flipped to allow it to go vertical. Link to comment Share on other sites More sharing options...
shurgen Posted December 7, 2005 Report Share Posted December 7, 2005 There is a stop on each side hinge that can be flipped to allow it to go vertical.Oh, thanks. That's good news as I won't have to remove the hood to get the engine out then. Link to comment Share on other sites More sharing options...
850R Sleeper Posted December 7, 2005 Author Report Share Posted December 7, 2005 Battery is just dead...I can get it jumped, but that's about it.And yes, there are two stops on either side of the hood that have small holes in them. If you open your hood, but not all the way, then push the clips down, the hood will open vertically. Volvo did this to make the entire engine bay more accessible while working on them. Link to comment Share on other sites More sharing options...
Trunks850R Posted December 7, 2005 Report Share Posted December 7, 2005 why cant you jump it off? Link to comment Share on other sites More sharing options...
850R Sleeper Posted December 7, 2005 Author Report Share Posted December 7, 2005 why cant you jump it off?jump it off?I can jump it and it will run, I was just wondering if anyone had any suggestions as to what it could be. Link to comment Share on other sites More sharing options...
shurgen Posted December 7, 2005 Report Share Posted December 7, 2005 Were your battery terminals clean and most importantly tight? I bet this is the problem Link to comment Share on other sites More sharing options...
maiku Posted December 7, 2005 Report Share Posted December 7, 2005 so it jumps fine, but you can't start it?whip out a volt meter and tell us your voltage ratingsone with battery by itself, car not started (for battery voltage)and one with battery started (for alternator voltage) Link to comment Share on other sites More sharing options...
Guest AlvinL Posted December 7, 2005 Report Share Posted December 7, 2005 Agree ^^^You should get around 14 volts or a little more, maybe a little less, with engine running. That means alternator is good and most likely you have a cell in the battery that suddenly died. It happens. A good battery should read over 12 volts, fully charged. Just what I've seen, if I remember correctly... :) Link to comment Share on other sites More sharing options...
