hoyt Posted December 10, 2005 Report Share Posted December 10, 2005 My sister's stock CD changer took a fall and broke a few months ago. Wanted to get her a replacement for Christmas, but I'd be mailing it to her, for her to install it. So I want the most direct swap out type replacement. I read on blitzsafe's site about the Alpine converter plugs, but it sounds like that requires you to re-run the cd-changer cable from the radio to the truck (not interested in doing that). Doesn't someone make a converter for the trunk side of things so that I could toss in one of these Alpines without having to re-run any wires?Thanks!--hoyt Link to comment Share on other sites More sharing options...
rp850 Posted December 10, 2005 Report Share Posted December 10, 2005 If you are going to use an Alpine changer, you'll probably need something called a VOLALP adapter (about $40). I have a CHM-S620 and that's what I used. The M in the model number means it uses an M-bus type cnnection. It's not too tough to wire it up but you'll need to splice in 12V power for the changer. I'd probably stick with a volvo CD changer as it will be a plug and play solution.My sister's stock CD changer took a fall and broke a few months ago. Wanted to get her a replacement for Christmas, but I'd be mailing it to her, for her to install it. So I want the most direct swap out type replacement. I read on blitzsafe's site about the Alpine converter plugs, but it sounds like that requires you to re-run the cd-changer cable from the radio to the truck (not interested in doing that). Doesn't someone make a converter for the trunk side of things so that I could toss in one of these Alpines without having to re-run any wires?Thanks!--hoyt Link to comment Share on other sites More sharing options...
