13g
calgary850awd
  • Replies 32
So i am ready to replace my tired 13g in my 97 850 AWD. I am looking to upgrade at the same time. What is a direct swap in? The 15g or the 16t? And any advice on doing the swap?
Thanks in advance guys
CB
A 15g from a 96-97 will bolt in, as well as a 16t from a 98. I wouldn't do it without a chip.
A chip for either or just the 16t?
Both, if you want to make use of the added capabilities and suchnot.
And pertaining to Kev's comment - downpipes always help (bigger is better, go 3" ;) ) but you don't HAVE to change as long as your replacement has the same flange type as yours (eg, 13g should be straight flange, so later 15gs and most 16T/18T/19Ts should work).
OK...
your 1997 850 Turbo has a "straight outlet" turbo.
The turbocharger that will bolt on directly from it are a "straight-outlet" 15G out of a 1996 or 1997 850 Turbo or a "straight-outlet" 16T out of a 1998 S70 T5. Also, if you can find a "straight-outlet" 18T, that will also work. The 19T and 99+ 16T turbochargers come with an "angled" outlet, which would require to change your downpipe.
OK...
Awesome guys just what I was looking for!!!!!
CB
any ANY ANY 15g/16t/18t/19t will work ... all you need to do is keep your turbine housing(which is already a flat/straight 2 7/8" outlet) and use the center and compressor ...
so IF you were to find a conical 15g you could use the 15g and just sell the turbine housing which comes off in about 2 mins w/ one 10mm nut
you do NOT have to change downpipes unless you want to go to the angled outlet (3"). otherwise any TD04HL turbo you find off a FWD volvo will bolt right up no matter what flanged turbine housing it came w/
so say you wanted to get eric's 19t .... you could, just swap over the center/compressor and leave your turbine housing there and sell the angled outlet housing ... it really is as easy as that to swap these TD04's
So who has a turbo for sale? Anyone?
