JESSEXC Posted December 15, 2005 Report Share Posted December 15, 2005 do they use the same rods? just higher CR ... if so no reason not to besides not many fwd guys can tune for a higher CR setup ... just means you run less boost to make the same amount of power(tho you'll make gob loads more torque)yep, same rods Link to comment Share on other sites More sharing options...
thelostartof Posted December 15, 2005 Report Share Posted December 15, 2005 yep, same rodsso if the rods are the same .. and those are the weak points ... you can make the same amount of power it just needs a better tune ... which i think MORE should try doing around here as the increased CR will help loads w/ spool up time and low end power ... but hey not like the rwd guy know anything about 9.8:1 CR turbo motors Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted December 15, 2005 Report Share Posted December 15, 2005 so if the rods are the same .. and those are the weak points ... you can make the same amount of power it just needs a better tune ... which i think MORE should try doing around here as the increased CR will help loads w/ spool up time and low end power ... but hey not like the rwd guy know anything about 9.8:1 CR turbo motorslet's work on the tune part first Link to comment Share on other sites More sharing options...
