mikeys Posted December 14, 2005 Report Share Posted December 14, 2005 My Volvo mechanic told me not to worry about doing a transmission oil change on my 2000 S80 unless the oil was really dark and smelt bad. He said his experience is if once you change it, it seems to start giving you problems. I was just wanting to do it for preventive maintenance. What are your experiences with transmission oil changes?? Link to comment Share on other sites More sharing options...
MrWinkey Posted December 15, 2005 Report Share Posted December 15, 2005 That is a synthetic fluid and I would recommend changing it at 60k intervals? Just my personal preferance that is a GM tranny ya' know ;) Link to comment Share on other sites More sharing options...
Fisher Posted December 16, 2005 Report Share Posted December 16, 2005 By the time the fluid is burnt and dark, the transmission is probably toast. By waiting till your fluid is this bad, you increase the likelyhood that you have a lot of varnish build-up. The new fluid will break this stuff off and try to suspend it, carrying it to your vital parts and clogging things up. This is what causes problems. Regular drain and fills will keep the accumulation of clutch material and varnish to a minimum. I am not sure where the previous poster got his information, but your fluid is not likely synthetic unless you have had it serviced in the past. I like to do drain and fill (which only removes what is in the pan, not the torque converter) every 15k miles. I think 30k miles is the most I would go. This would be the time to service any filters also. Link to comment Share on other sites More sharing options...
Guest Another guest Posted December 16, 2005 Report Share Posted December 16, 2005 The transmission in your S80 is a GM trans, it uses DEXRON III, and also has a filter in there that should be changed. Change the fluid when it starts to turn brown or you see silt on the dip stick when you check it. Your mileage may varry but the brown fluid never lies. (change it) Link to comment Share on other sites More sharing options...
MrWinkey Posted December 16, 2005 Report Share Posted December 16, 2005 By the time the fluid is burnt and dark, the transmission is probably toast. By waiting till your fluid is this bad, you increase the likelyhood that you have a lot of varnish build-up. The new fluid will break this stuff off and try to suspend it, carrying it to your vital parts and clogging things up. This is what causes problems. Regular drain and fills will keep the accumulation of clutch material and varnish to a minimum. I am not sure where the previous poster got his information, but your fluid is not likely synthetic unless you have had it serviced in the past. I like to do drain and fill (which only removes what is in the pan, not the torque converter) every 15k miles. I think 30k miles is the most I would go. This would be the time to service any filters also.Yeah I'm not real sure where I get my information from either? ;) Link to comment Share on other sites More sharing options...
Fisher Posted December 17, 2005 Report Share Posted December 17, 2005 Winkey,Is the factory fill on that GM tranny a synthetic? Link to comment Share on other sites More sharing options...
A pimp named Slickback Posted December 19, 2005 Report Share Posted December 19, 2005 That car takes regular trans fluid, don't waste your money on synthetic. I believe the recommended changing interval with that car was every 22,500 miles. Link to comment Share on other sites More sharing options...
mikeys Posted December 19, 2005 Author Report Share Posted December 19, 2005 The dealer told me they would flush the tranny and didn't have to change the filter. She said the flush would clean the filter also? This is the dealer talking. They said they would do it for $199.95. Is this a fair price and would anyone use anyone other than the dealer? Link to comment Share on other sites More sharing options...
volvo4lif3 Posted December 19, 2005 Report Share Posted December 19, 2005 Seems very expensive.....Volvo told me my tranny was a sealed system, and that it wasn't necessary to change the tranny fluid at all.....I was asking this because my orginal transmission went out just before 100k......and I dont want it to happen again. Link to comment Share on other sites More sharing options...
mikeys Posted December 20, 2005 Author Report Share Posted December 20, 2005 Seems very expensive.....Volvo told me my tranny was a sealed system, and that it wasn't necessary to change the tranny fluid at all.....I was asking this because my orginal transmission went out just before 100k......and I dont want it to happen again.What was the cause of your first tranny going to the grave? My Volvo dealer says change it and yours says don't, I guess I need one more input from someone elses Dealer to break this tie so I can deside on whether to change it or not. I really do want to change it just for sake of mind, but $199.95 seems like a crap load for just changing fluid. :blink: Link to comment Share on other sites More sharing options...
01s60 Posted December 20, 2005 Report Share Posted December 20, 2005 how is the s80 transmission a GM trans when volvo is owned by ford :huh: Link to comment Share on other sites More sharing options...
volvo4lif3 Posted December 20, 2005 Report Share Posted December 20, 2005 No clue, but its a GM tranny. Link to comment Share on other sites More sharing options...
dragon17 Posted December 21, 2005 Report Share Posted December 21, 2005 No clue, but its a GM tranny.Just like the new S80 is getting a Yamaha V8. Automotive partnerships? It's a shame that the GM tranny only has 4 speeds. Link to comment Share on other sites More sharing options...
MTPOCKITS Posted December 21, 2005 Report Share Posted December 21, 2005 its a gm for sure, change the filter and oil you will be happy. Link to comment Share on other sites More sharing options...
MrWinkey Posted December 24, 2005 Report Share Posted December 24, 2005 Winkey,Is the factory fill on that GM tranny a synthetic?No it's not that's why I said what I did???.... :lol: Link to comment Share on other sites More sharing options...
