rodrigo Posted December 15, 2005 Report Share Posted December 15, 2005 :huh: yes?no? Link to comment Share on other sites More sharing options...
the underlørd Posted December 15, 2005 Report Share Posted December 15, 2005 yes?no?front doors..i would guess yes. Link to comment Share on other sites More sharing options...
rodrigo Posted December 15, 2005 Author Report Share Posted December 15, 2005 I would too, but I'm not sure.a friend overseas needs help, and Im trying to find out for him. :) Link to comment Share on other sites More sharing options...
Guest Guest Posted December 15, 2005 Report Share Posted December 15, 2005 I would too, but I'm not sure.a friend overseas needs help, and Im trying to find out for him. It is my understanding you cannot buy just a motor, but a whole "cartride" which is the whole assembly. I could be wrong. But if I'm right, it is probably not the same because the door is so much larger. Link to comment Share on other sites More sharing options...
Guest Guest Posted December 15, 2005 Report Share Posted December 15, 2005 It is my understanding you cannot buy just a motor, but a whole "cartride" which is the whole assembly. I could be wrong. But if I'm right, it is probably not the same because the door is so much larger.And usually the motor does not fail - the little platic pulleys do. Is he sure it's the motor? Link to comment Share on other sites More sharing options...
Guest guest #2 Posted December 16, 2005 Report Share Posted December 16, 2005 the window motors are not the same on those two cars. The C70 has what is called a window cassette, that has the motor, cables, plastic pulleys etc. The replacement requires the transfer of your window to the new cassette. Link to comment Share on other sites More sharing options...
rodrigo Posted December 17, 2005 Author Report Share Posted December 17, 2005 man....how come you guys do not register???givin the info, and we dont even know who you are...thanks :) Link to comment Share on other sites More sharing options...
jem-c70 Posted December 17, 2005 Report Share Posted December 17, 2005 man....how come you guys do not register???givin the info, and we dont even know who you are...thanks I have a problem with my drivers side window.....theres a grinding sound when the window is lowered and sometimes the window will stick, i have to pull the window up.I removed the door panel to inspect the motor, since I've replaced several power window motors.I could not believe what i was looking at, steel cables and plastic pulleys to move a window up and down.I think volvo has MORONS in their designing and engineering dept.To fix the window will require a complete window REGULATOR ASSEMBLY.....$500 for the part and about $400 labor. Link to comment Share on other sites More sharing options...
rodrigo Posted December 17, 2005 Author Report Share Posted December 17, 2005 :blink: big bling for a window, man! Link to comment Share on other sites More sharing options...
starfish Posted December 18, 2005 Report Share Posted December 18, 2005 I have a problem with my drivers side window.....theres a grinding sound when the window is lowered and sometimes the window will stick, i have to pull the window up.I removed the door panel to inspect the motor, since I've replaced several power window motors.I could not believe what i was looking at, steel cables and plastic pulleys to move a window up and down.I think volvo has MORONS in their designing and engineering dept.To fix the window will require a complete window REGULATOR ASSEMBLY.....$500 for the part and about $400 labor.The C70 window cassette is probably ranked as the all time number one in the industry for engineering abominations! There has got to be atleast 42 different adjustments on the thing! Good luck trying to change it yourself. :( Link to comment Share on other sites More sharing options...
rodrigo Posted December 19, 2005 Author Report Share Posted December 19, 2005 I will pass on this useful info.Is this common on C's? Link to comment Share on other sites More sharing options...
