Edawg Posted December 17, 2005 Report Share Posted December 17, 2005 My 2002 S60 2.4T has is due for a transmission service and the dealer quoted me $400 dollars, due to the special O.E. Volvo fluid that is recommended, evidently it's expensive. I was told my car takes ATF 4 from another source...Is this true? What are my options as far as ATF fluids? Would Mobil 1 ATF work? I have the geartronic trans..Suggestions please..Thanks Ruftek. Link to comment Share on other sites More sharing options...
Fisher Posted December 17, 2005 Report Share Posted December 17, 2005 Call up your Mobil distributor and ask for Mobil 3309. Mobil 3309 is the equivalent product for Volvo's 1161540- 8. Mobil 1 will not work. Amsoil is a synthetic choice. Somebody also said Valvoline Maxlife ATF would work, don't know for sure.I believe you can even buy a case of the Mobil 3309 and take it to the dealer for use in the service. Probably depends on the dealer.There is more information in these forums you can find if you do a search. Link to comment Share on other sites More sharing options...
the underlørd Posted December 18, 2005 Report Share Posted December 18, 2005 Call up your Mobil distributor and ask for Mobil 3309. Mobil 3309 is the equivalent product for Volvo's 1161540- 8. Mobil 1 will not work. Amsoil is a synthetic choice. Somebody also said Valvoline Maxlife ATF would work, don't know for sure.I believe you can even buy a case of the Mobil 3309 and take it to the dealer for use in the service. Probably depends on the dealer.There is more information in these forums you can find if you do a search.100% correct. Link to comment Share on other sites More sharing options...
dlugi Posted December 18, 2005 Report Share Posted December 18, 2005 Call up your Mobil distributor and ask for Mobil 3309. Mobil 3309 is the equivalent product for Volvo's 1161540- 8. Mobil 1 will not work. Amsoil is a synthetic choice. Somebody also said Valvoline Maxlife ATF would work, don't know for sure.I believe you can even buy a case of the Mobil 3309 and take it to the dealer for use in the service. Probably depends on the dealer.There is more information in these forums you can find if you do a search.what is product no. 1161621 ? for auto transmission (ie.non-geartronic) ? is there an equivalent Mobil product ?thanks Link to comment Share on other sites More sharing options...
