bmwtinut Posted December 18, 2005 Report Share Posted December 18, 2005 I was changing the tires on my new to me '00 V70R and thought I would check the front engine mount while I had the wheel off and noticed that there was alot of oil on the lower part of the subframe and engine. What should I be looking for? When I bought the car back in August the engine was very clean and all it ran great. I did look at the front of the engine and didn't see anything then. I took a quick look at it and can't seem to see a point of origin. Anyone have any suggestions?ThanksTodd Link to comment Share on other sites More sharing options...
the underlørd Posted December 18, 2005 Report Share Posted December 18, 2005 get it all cleaned up, then put a piece of carboard under where you think the leak is coming from... then you should be able to pinpoint the leak. let's hope it's not a RMS/ Link to comment Share on other sites More sharing options...
bmwtinut Posted December 20, 2005 Author Report Share Posted December 20, 2005 What do you mean by RMS, rear main seal? I am thinking that it might be the crank seal. Link to comment Share on other sites More sharing options...
Kibim Posted December 20, 2005 Report Share Posted December 20, 2005 You need to clean it all up 'n see, but turbo-seals are fairly common to leak. It's an easy/cheap fix too. Link to comment Share on other sites More sharing options...
bmwtinut Posted December 21, 2005 Author Report Share Posted December 21, 2005 Well I don't think it is the turbo seals. I had the drain seal leaking on my AWD and the leak was not like this. This is only at the front of the engine. I did notice that this morning there were a couple of drops on the driveway. It will be going in to the dealer on Tuesday to be looked at. Link to comment Share on other sites More sharing options...
mikeys Posted December 21, 2005 Report Share Posted December 21, 2005 Maybe the flame trap/oil trap??? On my S80 it would pour oil out every so often out of the oil trap seal. I had it the oil trap and seal replaced and bye bye leak. Good luck! Link to comment Share on other sites More sharing options...
MrWinkey Posted December 24, 2005 Report Share Posted December 24, 2005 If it was the RF tire are you sure you don't have a power steering leak? ;) Link to comment Share on other sites More sharing options...
