rodrigo Posted December 20, 2005 Author Report Share Posted December 20, 2005 So no codes yet, and I passed inspection.So good so far! Link to comment Share on other sites More sharing options...
the underlørd Posted December 20, 2005 Report Share Posted December 20, 2005 So no codes yet, and I passed inspection.So good so far!HAAH YESSSS...niice man.. keepin the fingers crossed. Link to comment Share on other sites More sharing options...
Dinardo Posted December 21, 2005 Report Share Posted December 21, 2005 I posted here a while back with a couple of codes my XC was dishing out. At the time, I did not have too much time to look into the remedy for these codes and took the car to my trusty mechanic. After 4 visits (no charge), and the codes coming up again, I have had it, and before I go to the dealer with it (still under warranty) I figured I would try and fix it myself...now I have time (but the temprature is -freezing...yey me!) So here are the codes the scan tool is pumping out:P0422 P1174What are they?I am reasonably mechanically inclined, but I have no idea what these codes mean, and how to diagnose them, as codes can be from a variety of things in the same circuit, from what I have read here.I have noticed no driveability issues with the car, but I dont wanna drive it too much if the light is on since, to me, it should not be on in the first place.TIA for your helps! Link to comment Share on other sites More sharing options...
rodrigo Posted December 21, 2005 Author Report Share Posted December 21, 2005 ^^ ^^ huh? Link to comment Share on other sites More sharing options...
rodrigo Posted December 22, 2005 Author Report Share Posted December 22, 2005 So the effing light came on effing again while I was driving home from work. happy, I am!So here's what the scanner says: P1174 again: manufacturer controlled fuel and air metering. Also, it took 63 miles for it to come on, so I reset the light again and see if ti takes the same mileage for it to turn on next time.So, I think the next step is to go to Volvo and see if they car take care of the MAF/CAT under waranty.what you guys think? Link to comment Share on other sites More sharing options...
rodrigo Posted December 23, 2005 Author Report Share Posted December 23, 2005 AAARRRGGGHHH!!!!!!!the light is on again...35 miles after the reset.'bend-me-over-and-stick-me'-ship(read as 'dealership)': here I come. <_< Link to comment Share on other sites More sharing options...
rodrigo Posted December 23, 2005 Author Report Share Posted December 23, 2005 So I hit it up with the scanner and I got: 1171 ?First, in the beginning of the week, I got P0422 and P1174now P1171...WHAT THE HELL IS WRONG WITH THIS POS!!??!!??!!??!!?? :) Link to comment Share on other sites More sharing options...
Fisher Posted December 23, 2005 Report Share Posted December 23, 2005 My guess is an O2 sensor. 45K is not too early for one of these to fail. Link to comment Share on other sites More sharing options...
MrWinkey Posted December 24, 2005 Report Share Posted December 24, 2005 Well ok..since no one else will chime in.....your 1171 is possibly a vacuum leak look at the rubber elbow on the pass. side of the intake..the 1174 is also related to that as well....the 0422 is an evap code I believe and I think it's for the valve on the rad shroud but not sure just going off of memory. I highly doubt ANY of those codes are related to an 0/2 sensor...the 1171 and1174 are fuel trim codes and if you have no vacuum leaks you may possibly need and AMM but without reading values I cannot say? ;) Link to comment Share on other sites More sharing options...
rodrigo Posted December 24, 2005 Author Report Share Posted December 24, 2005 So, ok...we narrow it down to fuel trim.Tomorrow I will check do a rubber elbow check.AMM...i'm goign to look at the pinned section and see what that means.Thanks for all your paitence(s)...but I hate the light coming on is that AMM: Air Mass Meter, or Mass Airflow Sensor: MAF? Link to comment Share on other sites More sharing options...
rodrigo Posted December 24, 2005 Author Report Share Posted December 24, 2005 Just an update.I cleared the code and 23 miles later, it came up again: P1171: manufacturer controlled fuel and air metering. <_< Link to comment Share on other sites More sharing options...
BtownVolvo Posted December 24, 2005 Report Share Posted December 24, 2005 is that AMM: Air Mass Meter, or Mass Airflow Sensor: MAF?Same thing... Link to comment Share on other sites More sharing options...
rodrigo Posted December 24, 2005 Author Report Share Posted December 24, 2005 thank you. I'll be busy tomorrow looking at these elbows... Link to comment Share on other sites More sharing options...
BCo Posted December 24, 2005 Report Share Posted December 24, 2005 thank you. I'll be busy tomorrow looking at these elbows...It doesn't matter how long it takes for the light to come back on. That just depends on what kind of driving you are doing following the reset. If you satisfy the ideal "drive cycle" twice, the computer can run all its diagnostics and decide whether to anger you with a CEL, or keep you happy. See drive cycle instructions in this post.I agree, sounds like vacuum leak(s). Link to comment Share on other sites More sharing options...
rodrigo Posted December 24, 2005 Author Report Share Posted December 24, 2005 thanks for the info in a the drive...Guess who'll be getting up tomorrow at 5:00 am, and not to open up presents. while looking for the vaccuum leak, can i use ether to spray and help find the leak? Link to comment Share on other sites More sharing options...
