kenk Posted May 18, 2004 Report Share Posted May 18, 2004 I thought there was something in the archives about oil lights flashing, and someone who had a failed oil pump, but i cant find it after searching for a bit....My oil light flashes for like 1-2 seconds after starting, (after all the other lights go out) usually only after the car has sat for at least 24 hours. I had this once before but that was when a nice guy mechanic used a non volvo oil filter without check valve, but swapping it out fixed that.the light started flashing after my most recent oil change, is this a sign of a oil pump going out....? Is it normal for the oil to drip down while the car is sitting? I thought the check valve fixed that..... could i jsut have a faulty check valve in my filter?thanks a Bunch!:-)kkames iowa. Link to comment Share on other sites More sharing options...
Bay13 Posted May 19, 2004 Report Share Posted May 19, 2004 Need to know what kind of car you have? Link to comment Share on other sites More sharing options...
Guest Guest_kenk Posted May 19, 2004 Report Share Posted May 19, 2004 1996 850 NA, 161k. 5sp. Mostly highway. Link to comment Share on other sites More sharing options...
Bay13 Posted May 20, 2004 Report Share Posted May 20, 2004 Well I'd go with a new filter, use 10w30 weight oil, have the oil pressure checked to verify if there is in fact low pressure, then go from there. Link to comment Share on other sites More sharing options...
