prasamin Posted April 24, 2007 Report Share Posted April 24, 2007 don't you need some sort of adapter to fit the t3 turbo onto the s60R manifold? with it milled flat like that, will the turbo seal to the manifold without a gasket of some sort? Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted April 24, 2007 Report Share Posted April 24, 2007 don't you need some sort of adapter to fit the t3 turbo onto the s60R manifold? with it milled flat like that, will the turbo seal to the manifold without a gasket of some sort?Looks to me like it was just milled flat and I'm pretty sure I see a t3 inlet gasket on there. :huh: Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted April 24, 2007 Report Share Posted April 24, 2007 How much clearance from the cyl walls you have at 10mm lift on the exhaust valves?bump... any answer Scott? Link to comment Share on other sites More sharing options...
TM850R Posted April 24, 2007 Report Share Posted April 24, 2007 This is really coming along. Did you have to modify the firewall at all in order to fit that HUGE turbo in there. It looks like it may be a tight fit. Link to comment Share on other sites More sharing options...
ultra_runner Posted April 24, 2007 Author Report Share Posted April 24, 2007 don't you need some sort of adapter to fit the t3 turbo onto the s60R manifold? with it milled flat like that, will the turbo seal to the manifold without a gasket of some sort?Looks to me like it was just milled flat and I'm pretty sure I see a t3 inlet gasket on there. Correct. I could have used an adapter from ATP but that adds to height and depth of the turbo position. Mill the flange flat, drill and tap some 10mm studs then use the metal T3 gasket.Let me give a shout on to CJ on that drilling and tapping. It's pretty hard to get excited about drilling and tapping a manifold, but CJ is such a perfectionist on everything he does - I was totally engrossed with his work!!!How much clearance from the cyl walls you have at 10mm lift on the exhaust valves?bump... any answer Scott?Don't really know. This is really coming along. Did you have to modify the firewall at all in order to fit that HUGE turbo in there. It looks like it may be a tight fit.Firewall? Who needs a stinkin' firewall? Just kidding! It will be a tight fit... but, it will fit. Worst case I can use some Astroglide and a baseball bat.Scott C. Link to comment Share on other sites More sharing options...
stick70 Posted April 24, 2007 Report Share Posted April 24, 2007 Man, ive been following this from the beginning, and i must say its good to see it all starting to come together. I love crunch time! :D Link to comment Share on other sites More sharing options...
BlackT5 Posted April 24, 2007 Report Share Posted April 24, 2007 Looks great Scott! Have you made your final decision on tuning yet?...and if you just machine the lip off the manifold and don't use the adaptor, it fits. It's closer to the mount than the firewall. Link to comment Share on other sites More sharing options...
ultra_runner Posted April 24, 2007 Author Report Share Posted April 24, 2007 Looks great Scott! Have you made your final decision on tuning yet?...and if you just machine the lip off the manifold and don't use the adaptor, it fits. It's closer to the mount than the firewall.Thanks for the pics - great reference. That would be the mount for an M56 - no? I have a custom made mount for the M66 because the bracket is completely different. So, it was fabbed to mount the M66 (S60R base) to the motor mount of an 850. I may run into clearance issues there but won't know until I drop it in.Scott C. Link to comment Share on other sites More sharing options...
BlackT5 Posted April 24, 2007 Report Share Posted April 24, 2007 DuhhYea, I totally forgot about the M66. haha Link to comment Share on other sites More sharing options...
NGB Posted May 10, 2007 Report Share Posted May 10, 2007 Scott, what are the updates? Link to comment Share on other sites More sharing options...
Boomin850 Posted May 10, 2007 Report Share Posted May 10, 2007 He's out of the country Link to comment Share on other sites More sharing options...
absolutrk Posted June 7, 2007 Report Share Posted June 7, 2007 Wow, I just read through the whole thread, not quite sure if it would be finished by the time i got to the last page. This is by far the coolest thing I've seen in a long time. I've wanted to do this myself to an 855 for a very long time. I wish I knew this much about tuning and rebuilding cars, but *sigh* I will have to settle for living through you.Great job on this, looking forward to the final product! :tup: Link to comment Share on other sites More sharing options...
850turbo Posted June 7, 2007 Report Share Posted June 7, 2007 Hey Scott i see that you are running a MSD coil. You may wanna look at this and pick up a resistor. Link to comment Share on other sites More sharing options...
ultra_runner Posted June 18, 2007 Author Report Share Posted June 18, 2007 Hey Scott i see that you are running a MSD coil. You may wanna look at this and pick up a resistor.Thanks. Will look into it as soon as the allow me off this military reservation!!! Seeking to be home for a bit come mid-July.Scott C. Link to comment Share on other sites More sharing options...
ultra_runner Posted July 29, 2007 Author Report Share Posted July 29, 2007 Ok, I'm back in town for a couple of days. I got the Spec Stage 3+ clutch kit installed and the trans bolted up along with the oil return line. I am going to try to get the engine into the car tonight (beer pending) or tomorrow.Stay tuned.Scott C. Link to comment Share on other sites More sharing options...
