banksie312 Posted December 25, 2005 Report Share Posted December 25, 2005 ok so i started puttin in the EST air intake system (with heat sheild) and immediately ran into problemsthey dont seem to account for (or atleast i may be missing things...to restate i am a n00b engine wise but follow instructions and catch on well) a few thingsthere his a hose coming from the front of the turbo seen here:it doesnt say what to do with that OR where it goes to, i did read the instructions all the way through also, i loosened the clamp as instructed right where the arrows are pointingit will not come offwhat am i supposed to do about the object in the red square?im sorry that i am such a n00b and if anyone has installed this please let me know what the Air Mass Meter is (is that the thing in the red box? and if so how to remove it?)the step i am on which is before removing the upper portion of the air box says"2. Remove the Air Mass Meter by loosening the hose clamp that attach the Air Mass Meter the to plastic tube."remember that i already loosened the clamp shown in pictures 2+3 by the red arrows and that it is very loose but i cannot pull the 2 pieces apartthanks guys, im sure ill have more questions Link to comment Share on other sites More sharing options...
banksie312 Posted December 25, 2005 Author Report Share Posted December 25, 2005 ok i got the top of the turbo box off partially but the hose towards the front of the car that leads down under the engine i do not understandi just looked at my brothers 850 turbo and it isnt there, which is where the pictures for the EST instructions are fromanyone wanna help methe hose is the arrow in the first pictureok i got the top of the turbo box off partially but the hose towards the front of the car that leads down under the engine i do not understandi just looked at my brothers 850 turbo and it isnt there, which is where the pictures for the EST instructions are fromanyone wanna help methe hose is the arrow in the first picture Link to comment Share on other sites More sharing options...
550 Posted December 25, 2005 Report Share Posted December 25, 2005 That hose... is what goes to the air pump. Just letting you know the turbo aint under that box... just for information sake.Take that hose off... that breather filter (the little filter) goes on that hose.As for the MAF... you need to take the t25 or t20 torx screws off of the box itself. Link to comment Share on other sites More sharing options...
banksie312 Posted December 25, 2005 Author Report Share Posted December 25, 2005 That hose... is what goes to the air pump. Just letting you know the turbo aint under that box... just for information sake.Take that hose off... that breather filter (the little filter) goes on that hose.As for the MAF... you need to take the t25 or t20 torx screws off of the box itself.ok, so where do i mount the minature air filter?does it go in the large hole in the heat shield that isnt being used for the cone filter?thank you so much Link to comment Share on other sites More sharing options...
550 Posted December 25, 2005 Report Share Posted December 25, 2005 well you can do one of two things... you can mount it in that hole with the filteror just put it on the hose and put the hose whereverGreg cut his hose down so it sits more by the headlight now, and it just has the filter on it. Link to comment Share on other sites More sharing options...
Volvoson Posted December 25, 2005 Report Share Posted December 25, 2005 ok, so where do i mount the minature air filter?does it go in the large hole in the heat shield that isnt being used for the cone filter?thank you so muchYou mount the mini-filter on the end of that smaller rubber tube :) Link to comment Share on other sites More sharing options...
550 Posted December 25, 2005 Report Share Posted December 25, 2005 hah carson, I beat you! Link to comment Share on other sites More sharing options...
banksie312 Posted December 25, 2005 Author Report Share Posted December 25, 2005 awesomethanks guys Link to comment Share on other sites More sharing options...
550 Posted December 25, 2005 Report Share Posted December 25, 2005 yeah, good luck mang Link to comment Share on other sites More sharing options...
Volvoson Posted December 25, 2005 Report Share Posted December 25, 2005 hah carson, I beat you!Warn level +10 :ph34r: Link to comment Share on other sites More sharing options...
banksie312 Posted December 25, 2005 Author Report Share Posted December 25, 2005 haha oh man another thingok so i have the heat shield in place but didnt secure it yeti am completely baffled by the use of the bracketi understand its supposed to hook up to the air regulator? but what is the air regulator and where?!and in which direction does the bracket go?my car is a 98 and it says you need to hook the air regulator to the bracket Link to comment Share on other sites More sharing options...
Volvoson Posted December 25, 2005 Report Share Posted December 25, 2005 haha oh man another thingok so i have the heat shield in place but didnt secure it yeti am completely baffled by the use of the bracketi understand its supposed to hook up to the air regulator? but what is the air regulator and where?!and in which direction does the bracket go?my car is a 98 and it says you need to hook the air regulator to the bracketPost pictures of how far you are, then we can talk you through it.I believe the Air Regulator is the MAF, and it bolts onto the heatshield one way. I found it kinda hard to attach the other piece of the firewall to the fender using the hardware, but I eventually got it Anyways, just show us with pics where you are. Link to comment Share on other sites More sharing options...
banksie312 Posted December 25, 2005 Author Report Share Posted December 25, 2005 okhere are the picsi dont even know where (or what for that matter) the MAF is (i actually might but dont remember/know how it applies)thanks Link to comment Share on other sites More sharing options...
Brickster151 Posted December 25, 2005 Report Share Posted December 25, 2005 stick the big filter over the MAF [the round "thing" with the square "stuff" in it] and install the little filter on the tube and you're done. Link to comment Share on other sites More sharing options...
viperman135 Posted December 25, 2005 Report Share Posted December 25, 2005 Looks like you are almost there. The MAF is the sensor where that wire goes into and then the filiter plugs in on to the end of that. For the looks of it all you have to do it put the filiter on.As for the hose that goes to the air pump. Look at the far left of the pic. I just cut the pipe down and put this cheapo filter over it. Works until I can find something better. Link to comment Share on other sites More sharing options...
