MWvolvo850 Posted May 18, 2004 Report Share Posted May 18, 2004 Can anyone provide me with detailed information on how to install a Volvo trip computer? This is for a 1995 Volvo 850 GLT.Thanks. Link to comment Share on other sites More sharing options...
JESSEXC Posted May 18, 2004 Report Share Posted May 18, 2004 Very easy about a 30 min job. I installed mine using the directions on this page about 2 years ago.850 Instrument Cluster removal Remove the clock and replace with the trip computer. Pop out one of the dash blanks. Replace with the trip computer switch and you are done. Good luck Link to comment Share on other sites More sharing options...
Figawi Posted May 18, 2004 Report Share Posted May 18, 2004 make sure you buy ALL the wiring needed Link to comment Share on other sites More sharing options...
MWvolvo850 Posted May 19, 2004 Author Report Share Posted May 19, 2004 All is going good so far. Im at the point of disconnecting the old computer unit and replacing it with the new. Should I disconnect the battery and or anything else? Link to comment Share on other sites More sharing options...
MWvolvo850 Posted May 19, 2004 Author Report Share Posted May 19, 2004 I got it all installed! However, I left a smudge mark on the LCD display before I installed it... Guess I will wait for a panel light to burn out then clean off the smudge :lol: Link to comment Share on other sites More sharing options...
JehovArob Posted May 19, 2004 Report Share Posted May 19, 2004 You can just install a trip computer, eh? What all does it do and how much do they cost? Link to comment Share on other sites More sharing options...
maiku Posted May 19, 2004 Report Share Posted May 19, 2004 i read that you had to get the dealer to "activate" itcould you guys explain what you EXACTLY needed to get it to work? Link to comment Share on other sites More sharing options...
MWvolvo850 Posted May 19, 2004 Author Report Share Posted May 19, 2004 The unit is plug and play. It works as it should without any reprogramming...etc Link to comment Share on other sites More sharing options...
maiku Posted May 19, 2004 Report Share Posted May 19, 2004 really?cool! i might just go to my local junkyard and scrape one up Link to comment Share on other sites More sharing options...
GLT (Great Little Turbo) Posted May 27, 2004 Report Share Posted May 27, 2004 I recently bought a trip computer and dash switch from a seller on ebay. The parts were from a 96 850. My car is a 97 GLT wagon that had only the clock/temp display unit. I just followed the cluster removal instructions on BAY 13 and it went in very easily and all functions seem to work fine. Only problem I've noticed is that the odometer on the computer is running about 10% ahead of the mechanical speedometer. So 10 miles on the computer reads as 9 on the speedometer. Is this normal? Which one is correct? TIP:If you are going to do any work on the cluster, best to have a good supply of both types of bulbs and just replace them all so you won't have to pull it all apart again for a while. I also recommend using a small bungee cord to hold the left end of the dash up out of the way. Clip it to the visor bracket. Link to comment Share on other sites More sharing options...
blue cube Posted May 27, 2004 Report Share Posted May 27, 2004 what are the features of the trip computer? Link to comment Share on other sites More sharing options...
Figawi Posted May 27, 2004 Report Share Posted May 27, 2004 mpg, avg mpg, temp, total distance, miles left until empty Link to comment Share on other sites More sharing options...
Guest Guest Posted May 27, 2004 Report Share Posted May 27, 2004 does it hook into the ecu somehow??? Link to comment Share on other sites More sharing options...
blue cube Posted May 27, 2004 Report Share Posted May 27, 2004 oh great now im having problems logging in Link to comment Share on other sites More sharing options...
