ras1 Posted January 1, 2006 Report Share Posted January 1, 2006 Hey everybody new to the site, i have a 2000 v40 and while driving it the other day it started stalling out at low RPM's i was able to limp it home by keeping my foot on the accelerator while braking.Any ideas what my issue is, when parked it will not idle on its own, as soon as i take my foot off the gas it dies.PLEASE HELPTHANKS Link to comment Share on other sites More sharing options...
MrWinkey Posted January 1, 2006 Report Share Posted January 1, 2006 Well welcome to the site.....as for your problem could be a couple things? But more than likely a large vacuum leak..if the car is a turbo you may want to inspect the intake charge hoses assuming you have no CEL ;) Link to comment Share on other sites More sharing options...
Black Beauty T4 Posted January 2, 2006 Report Share Posted January 2, 2006 If you cannot find a vacuum leak, try thoroughly cleaning the throttle body with carb cleaner (get it in an aerosol can with a long nozzle to get right in there).Repeat every 20,000 miles.Good luck.BB :tup: Link to comment Share on other sites More sharing options...
Guest Guest_Rob_* Posted January 2, 2006 Report Share Posted January 2, 2006 Well welcome to the site.....as for your problem could be a couple things? But more than likely a large vacuum leak..if the car is a turbo you may want to inspect the intake charge hoses assuming you have no CEL Thanks for the input i will check out the hoses as this is a turbo Link to comment Share on other sites More sharing options...
