tp_taylor Posted January 2, 2006 Report Share Posted January 2, 2006 Seen these stabilizer/ground dist. kits on the Ebay for sale. Didn't know if they would really improve (especially a 5-8 hp gain)? Sounds really far fetched, but a good ground should improve the car electrics/ecu. Just wondering if a stabilizer is really worth it. Thoughts? Like a capacitor for your ECU/starter? Thanks for the non-lethal replies. Link to comment Share on other sites More sharing options...
Mesoam Posted January 2, 2006 Report Share Posted January 2, 2006 no, just redo all of your ground wires with some nice 4gauge wire Link to comment Share on other sites More sharing options...
mAydAy Posted January 2, 2006 Report Share Posted January 2, 2006 If they will actually stabilize the voltage it should help.Many of the EFI components use variances in voltage to meter and control different aspects of the engine. Different voltages will yield different results, so in theory, if you can stabilize the voltage you can stabilize and increase the overall accuracy of the fuel injection system by holding the baseline voltage for all sensors, senders, and everything constant, taking out another variable from the system. Link to comment Share on other sites More sharing options...
merlin390 Posted January 2, 2006 Report Share Posted January 2, 2006 Its a capacitor. Link to comment Share on other sites More sharing options...
WhiteT5 Posted January 2, 2006 Report Share Posted January 2, 2006 http://www.caraudiomag.com/testreports/0401cae_hyper/ Link to comment Share on other sites More sharing options...
turbor850 Posted January 2, 2006 Report Share Posted January 2, 2006 no, just redo all of your ground wires with some nice 4gauge wireyeah, have someone local that is good at it do it for you . . . .right Trav ? ? ? ? :rolleyes: Link to comment Share on other sites More sharing options...
tp_taylor Posted January 2, 2006 Author Report Share Posted January 2, 2006 I can def add a daisy-chained ground to my car myself. Got the wire and connections, just need time. That article indicated 9hp gain, just from a good ground? And I only got 4hp's from the lighted valve stem caps...So is that a "not worth it" for the voltage stabilizer? Link to comment Share on other sites More sharing options...
KS_R Posted January 2, 2006 Report Share Posted January 2, 2006 apexi has a voltage stablilizer. i would really like to see if it works. but i don't have 150 to drop on a little box. Link to comment Share on other sites More sharing options...
tp_taylor Posted January 3, 2006 Author Report Share Posted January 3, 2006 Me and mAyDaY will prob do a little more research and see if it is worth the while. Will post... Link to comment Share on other sites More sharing options...
