W.A. Lancaster Posted January 2, 2006 Report Share Posted January 2, 2006 Thinking very seriously about using these in the front of my C70 Coupe. Anyone have these or know of any fit problems? They are 6 1/2" components so they should simply bolt into stock locations. Thanks Andy Link to comment Share on other sites More sharing options...
Bing_0 Posted January 2, 2006 Report Share Posted January 2, 2006 well, you may need an adapter ring to fit the speaker in the stock location...but from my experience, if you going with something in the range of a boston pro, putting htem in the stock location is kinda of a waste. i have done set ups usinghte same speakers for 70 series both in kicks and stock locations, and the result is pretty dramatic b Link to comment Share on other sites More sharing options...
W.A. Lancaster Posted January 3, 2006 Author Report Share Posted January 3, 2006 well, you may need an adapter ring to fit the speaker in the stock location...but from my experience, if you going with something in the range of a boston pro, putting htem in the stock location is kinda of a waste. i have done set ups usinghte same speakers for 70 series both in kicks and stock locations, and the result is pretty dramatic b What exactly will the adapter ring do? The reason for the stock locations is a compromise between sound and appearance. Link to comment Share on other sites More sharing options...
Bing_0 Posted January 3, 2006 Report Share Posted January 3, 2006 well, assuming you hav ethe same door structure as a s70...thestock speaker is suspended in a ring type of stucture.this ring may or may not fit your bostons, you must fabricate this ring so to space hte spekaer out. once oyu tak ethe door off, you will see what i mean...but honestly. the performance of the stock door location, IMO, is mediocre at best...and where doy ou plan to put the tweet? i think the boston pros, whcih are harsh speakers to begin with, will make your ears bleed if you put the tweet in the stock dash location b Link to comment Share on other sites More sharing options...
