eurotrash_pd Posted January 8, 2006 Report Share Posted January 8, 2006 I'm getting a loud knock noise and a jolt when Drive or Reverse is selected. Also, the car rolls a little when put into park. The problem improves if the car is oneperfectly level gound but even the slightest incline will create problems. I was going to flush they tranny to try to improve this. The car is a 1998 C70 LPTCan anybody vouch for Red Line High Temp ATF?________________________________________________________________________________________Red Line High Temp ATF is perfect for heavily-loaded vehicles, this is a synthetic ATF which is a GL-4 gear oil for use where Dexron III or Mercon is recommended. Superior stability allows high-temperature operation without varnishing valves and clutches. Synthetic High-Temp ATF provides the gear protection of a GL-4 gear oil in an ATF and provides a higher viscosity at higher operating temperatures, allowing the transmission to operate at 70°F higher temperature and still provide the optimal shiftability and improved torque converter efficiency. The evaporation characteristics are significantly improved, being twice as good as our Synthetic ATF and five-times better than a petroleum ATF. The improved thermal stability significantly reduces the rapid evaporation of the ATF which can produce a frothing out the filler tube. The balanced frictional characteristics provides smooth and consistent shifts for extended drain intervals. The superior stability compared to petroleum ATFs allows high-temperature operation without varnishing valves and clutches which leads to transmission failure. This product can be used in manual transmissions which require ATFs and will provide much better gear protection than a petroleum ATF; however, MTL® will provide better wear protection and better low-temperature shiftability in most manual transmissions which call for an ATF. High-Temp ATF is suitable for use in automatic and manual transmissions and transaxles where Dexron III, Dexron II or Mercon is recommended. Link to comment Share on other sites More sharing options...
850drag Posted January 8, 2006 Report Share Posted January 8, 2006 i have used Redline ATF for now 4 years... it works very well.. stays cleans and really helps the life of the trans. I am currently using there racing atf also in my drag car and love the feel of it... great stuff... Link to comment Share on other sites More sharing options...
