brickbat Posted May 20, 2004 Report Share Posted May 20, 2004 We were driving today in our 96 850 and I noticed a dragging sensation, as if the E brake was on. It wasn't. I stopped to check and the front drivers side wheel was really hot. Hot enough to have discolored the normally orangeish-brown rust on the edge of the rotor to a nearly black color. No smoke, though. After it cooled off, the dragging problem went away for a few miles, then returned after a few more miles.So, should I order a new caliper, or is there some other possibility as to its cause?Jim Link to comment Share on other sites More sharing options...
Volvo OD Posted May 20, 2004 Report Share Posted May 20, 2004 If you can, remove the caliper try to turn the wheel. It may be the caliper or the parking brake. Link to comment Share on other sites More sharing options...
drPheta Posted May 20, 2004 Report Share Posted May 20, 2004 Sounds like a sticking/seized caliper. I had the same problem over the weekend. Rebuilt calipers cost about 50/per after core return. You can also have your rebuilt for about 60 bucks by a brake shop/rebuilder. Link to comment Share on other sites More sharing options...
