USMC850T Posted January 11, 2006 Report Share Posted January 11, 2006 I'm running a total of 2 degrees timing advance on my I & E camshafts, and here are my results.These were all obtained using a nice performance G-timer, which is quite accurate. It belongs to my friend, he has used it at the track with his S4 and found accuracy to about +-3 one hundreths on 1/4 mile runs. Anywho here it is.I did a whole bunch of 0-60 runs, and one uphill quarter mile. My best 60 run was 6.72 with a 2.35 60 foot time . I do have stuff all season continentals though. Incidentally, i had the most wheelspin on my best run. These are .2 sec better than my previous best of 6.93.In my graph I constructed a regression model to predict my speed after any given elasped time. It's dead on inside the data plots (R^2 = .99!), but gets a little fishy once you get around 10 seconds. I'm hoping to go out tomorrow and do some more 1/4 mile runs so that I have more data to fill in the graph with.How many others have experienced luck with the QBM tool. Link to comment Share on other sites More sharing options...
Gioseppe Posted January 11, 2006 Report Share Posted January 11, 2006 try different settings dude, and compare The results.do you have a boost/vac gauge hooked up? make note of vaccum readings at idle too. Link to comment Share on other sites More sharing options...
USMC850T Posted January 11, 2006 Author Report Share Posted January 11, 2006 try different settings dude, and compare The results.do you have a boost/vac gauge hooked up? make note of vaccum readings at idle too.I planned to change the settings after I had made 2-3 full 1/4 runs. I don't have a boost gauge though, what would I be recording idle vacumn for (sorry relative n00b). Link to comment Share on other sites More sharing options...
Mogatu'r Posted January 11, 2006 Report Share Posted January 11, 2006 How much stronger / faster, you felt your car after the Cam adjustment? err! Link to comment Share on other sites More sharing options...
Gioseppe Posted January 11, 2006 Report Share Posted January 11, 2006 I planned to change the settings after I had made 2-3 full 1/4 runs. I don't have a boost gauge though, what would I be recording idle vacumn for (sorry relative n00b).low vaccum = shitty idle. Link to comment Share on other sites More sharing options...
USMC850T Posted January 11, 2006 Author Report Share Posted January 11, 2006 My idle is right around 900 indicated on the tach. Once the cars been on for a few I can punch it to the floor and it will rev wihtout hesitation.As for how it feels, it feels faster because I shifted a little power into the midrange, so it comes on earlier. So far on paper it's .2 seconds faster. Link to comment Share on other sites More sharing options...
Nebor Posted January 11, 2006 Report Share Posted January 11, 2006 Stock boost, etc? Link to comment Share on other sites More sharing options...
Guest Guest Posted January 11, 2006 Report Share Posted January 11, 2006 Completely stock with exception to a cone filter coupled directly after the MAF and QBM cam adjustment. I used engine restore the first oil change after I bought the car and have been using mobil1. Link to comment Share on other sites More sharing options...
Nebor Posted January 11, 2006 Report Share Posted January 11, 2006 Completely stock with exception to a cone filter coupled directly after the MAF and QBM cam adjustment. I used engine restore the first oil change after I bought the car and have been using mobil1.That's not bad. I've got a downpipe, exhaust, and an mbc set at 12psi and I can only manage a 5.7s 0-60.If you threw on an alternate means of boost control, or a chip, so you could unleash first gear powah, then you could probably run a pretty hot 0-60. Link to comment Share on other sites More sharing options...
USMC850T Posted January 11, 2006 Author Report Share Posted January 11, 2006 I'm debating whether to go with a speedtuning chip, or spend more on an engine management system where I can have an economy map, and a balls to the wall power map. As for exhaust I'm gonna do a cutout. If I do the weight reduction I think I'd have no problem getting under 5.5 (with good rubber of course). Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted January 11, 2006 Report Share Posted January 11, 2006 That's not bad. I've got a downpipe, exhaust, and an mbc set at 12psi and I can only manage a 5.7s 0-60.If you threw on an alternate means of boost control, or a chip, so you could unleash first gear powah, then you could probably run a pretty hot 0-60.You forget, these cars get worse 0-60 as the power increases... they just refuse to get traction. Nice job recording the data man. Link to comment Share on other sites More sharing options...
piran21 Posted January 11, 2006 Report Share Posted January 11, 2006 You forget, these cars get worse 0-60 as the power increases... they just refuse to get traction. Nice job recording the data man.What do you think is the best 0-60 time that is possible with out MAJOR upgrades and street tires? I'm thinking like a low 5 second figure is possible. Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted January 11, 2006 Report Share Posted January 11, 2006 You'd have to classify major upgrades and street tires. :ph34r: Link to comment Share on other sites More sharing options...
BlackT5 Posted January 11, 2006 Report Share Posted January 11, 2006 What did you find your cams were set to before you made the adjustments? Link to comment Share on other sites More sharing options...
piran21 Posted January 11, 2006 Report Share Posted January 11, 2006 You'd have to classify major upgrades and street tires. I mean internal motor work. Stock turbo, stock tranny with bolt ons. No street drag radials. Summer tires at best. OK, play ball! Link to comment Share on other sites More sharing options...
