Matts 850 GLT Posted January 11, 2006 Report Share Posted January 11, 2006 HiYeah the car is getting old (1993) but anyway.When I brake there is twitch through the steering wheel. If I hold the wheel the car brakes in a straight line. I only get a twitch when I start to brake - even then it doesn't always do it?So, I am assuming a sticking caliper - which one? How do I tell?Any ideasThanksMatt Link to comment Share on other sites More sharing options...
robert213 Posted January 11, 2006 Report Share Posted January 11, 2006 Possible Warped Rotors. If I understanding correctly, Volvo rotors cannot be turned on a lathe. You may need to purchase new ones. Link to comment Share on other sites More sharing options...
Zappo Posted January 11, 2006 Report Share Posted January 11, 2006 HiYeah the car is getting old (1993) but anyway.When I brake there is twitch through the steering wheel. If I hold the wheel the car brakes in a straight line. I only get a twitch when I start to brake - even then it doesn't always do it?So, I am assuming a sticking caliper - which one? How do I tell?Any ideasThanksMatt This is what some call a warped rotor. Probably not actually warped, but sometimes pad material will build up on the rotor and make it uneven. Regardless, this is an early indication that your rotors will need to be replaced soon. The problem will only get worse as time goes on.If you had a sticking caliper, you would know because it would pull to one side. Sticking open would pull only when the brakes were applied, closed would pull after you released. Link to comment Share on other sites More sharing options...
Matts 850 GLT Posted January 11, 2006 Author Report Share Posted January 11, 2006 This is what some call a warped rotor. Probably not actually warped, but sometimes pad material will build up on the rotor and make it uneven. Regardless, this is an early indication that your rotors will need to be replaced soon. The problem will only get worse as time goes on.If you had a sticking caliper, you would know because it would pull to one side. Sticking open would pull only when the brakes were applied, closed would pull after you released.Thanks Zappo! Pads and disks are 13 months and 30,000 miles so I will go ahead and change them. Was thinking, wouldn't worn rotors cause a judder through brake pedal?All I get is a definate wrench at the steering wheel when I brake.Matt Link to comment Share on other sites More sharing options...
Guest Guest Posted January 11, 2006 Report Share Posted January 11, 2006 You will also get a pulsation in the steering wheel. Not expensive to do this. I did on 97 GLT for $140 to the door. Link to comment Share on other sites More sharing options...
shurgen Posted January 11, 2006 Report Share Posted January 11, 2006 Thanks Zappo! Pads and disks are 13 months and 30,000 miles so I will go ahead and change them. Was thinking, wouldn't worn rotors cause a judder through brake pedal?All I get is a definate wrench at the steering wheel when I brake.MattI doubt it's warped rotors, according to the description of the problem. Does car pull to one side when you brake? You wrote it brakes straight when you hold the wheel but does it pull or not? I'd take front wheels off and inspect not just braking system but suspension as well. Link to comment Share on other sites More sharing options...
