Asinine Posted January 16, 2006 Report Share Posted January 16, 2006 Can someone tell me where the ABS modual is?I was under the hood today and say that the 'tube' from the triple stack to the ecu box was not connected at the triple stack.i'm thinking that having the rear wheels locked while i'm spinning and powering out with the front caused the TRACS/ABS to overheat so much that those solder points loosened themselves.No matter, it's busted, but that might be an explanation!? Link to comment Share on other sites More sharing options...
Zappo Posted January 16, 2006 Report Share Posted January 16, 2006 Can someone tell me where the ABS modual is?I was under the hood today and say that the 'tube' from the triple stack to the ecu box was not connected at the triple stack.i'm thinking that having the rear wheels locked while i'm spinning and powering out with the front caused the TRACS/ABS to overheat so much that those solder points loosened themselves.No matter, it's busted, but that might be an explanation!? First of all, it is module. Second, that tube is to cool the ECU, the ABS unit is not on that side of the car. Look below the brake master cylinder. It is a black rectangular unit. Link to comment Share on other sites More sharing options...
Guest Guest_volvofan_* Posted January 16, 2006 Report Share Posted January 16, 2006 Here is more info on ABS modules absmodules.com Link to comment Share on other sites More sharing options...
