George @ ViVA Posted January 18, 2006 Report Share Posted January 18, 2006 We are pleased to announce that ViVA Performance is now a U.S. reseller of the 3rd EYE Tire Pressure Monitoring System (TPMS)!For a limited time, we are offering special, introductory pricing for the 3rd EYE TPMS. Included in the kit are four (4) tire sensors and an inside display/transmitter unit. We also offer additional tire sensors, for dedicated snow wheels/tires.Ordering Info:Place your order through our secure website:http://www.vivaperformance.com/parts/...d=338Introductory Price: InquireIf you have any questions, please send an email to :email: parts @ vivaperformance.com Link to comment Share on other sites More sharing options...
Volvoson Posted January 18, 2006 Report Share Posted January 18, 2006 That looks pretty snazzy George So, do the sensors just go onto the valve stem? Link to comment Share on other sites More sharing options...
KS_R Posted January 18, 2006 Report Share Posted January 18, 2006 i think they attach inside of the tire, if i understand how they work correctly. Link to comment Share on other sites More sharing options...
George @ ViVA Posted January 18, 2006 Author Report Share Posted January 18, 2006 Correct, they attach inside the valve stem. Really cool and useful. Link to comment Share on other sites More sharing options...
Sinbad Posted January 18, 2006 Report Share Posted January 18, 2006 Quick Q:Is the display a permanent fixture in the car, or could I buy 8 sensors and just put the display in whichever car I am driving that day?ThanksS Link to comment Share on other sites More sharing options...
George @ ViVA Posted January 18, 2006 Author Report Share Posted January 18, 2006 Quick Q:Is the display a permanent fixture in the car, or could I buy 8 sensors and just put the display in whichever car I am driving that day?ThanksSThe display/transmitter is hard wired to your car. It would be a semi-permanent fixture in your car, as you can still remove it if need be, but not for how you described it... Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted January 18, 2006 Report Share Posted January 18, 2006 These work out great on long trips! A friend of mine has one on his car and it has saved us a couple times from having to buy a new set of tires due to premature tire wear... due in part by low air pressure. Link to comment Share on other sites More sharing options...
Sinbad Posted January 18, 2006 Report Share Posted January 18, 2006 The display/transmitter is hard wired to your car. It would be a semi-permanent fixture in your car, as you can still remove it if need be, but not for how you described it...Thanks for the answer That's a pity - I need it in the volvo cos of the speeds I do, and in the kia for when I've deflated the tyres for beach mode and need to drive on the road for a short distance...Though.... credit limit on my CC just got extended... How much is shipping to LA?Thanks!S Link to comment Share on other sites More sharing options...
NataSS Inc Posted January 18, 2006 Report Share Posted January 18, 2006 Hey George, I have a couple of questions for you. 1) How often do the sensors sample the air pressure?2) How EXACTLY do these attach to the rim? Are they held onto the rim (inside the tire) with a steel band or are they affixed some other way. 3) If connected directly to the valve stem, will they work with a short all metal valve stem?Reason I ask these questions, is if all the answers are what I am looking for I will seriously consider purchasing one of these for my ORR race car. Tire temps and pressures are the biggest thing we are concerned with (other than debris) when it comes to tire failures because of the speeds we are running and the length of time at those speeds.ThanksThanks for the answer That's a pity - I need it in the volvo cos of the speeds I do, and in the kia for when I've deflated the tyres for beach mode and need to drive on the road for a short distance...Though.... credit limit on my CC just got extended... How much is shipping to LA?Thanks!SI am sure it would not be hard to splice a weather connector inbetween the hard wiring and the main unit and have the same wiring (custom made by yourself) with another weather connector in your second vehicle. That way you could "unplug" the sending unit and "plug" it back in, in the second vehicle. Link to comment Share on other sites More sharing options...
George @ ViVA Posted January 19, 2006 Author Report Share Posted January 19, 2006 How much is shipping to LA?Here are our applicable shipping rates:$150.01 to $299.99.....$15.00$300.00 to $599.99.....$25.00Hey George, I have a couple of questions for you. 1) How often do the sensors sample the air pressure?2) How EXACTLY do these attach to the rim? Are they held onto the rim (inside the tire) with a steel band or are they affixed some other way. 3) If connected directly to the valve stem, will they work with a short all metal valve stem?Reason I ask these questions, is if all the answers are what I am looking for I will seriously consider purchasing one of these for my ORR race car. Tire temps and pressures are the biggest thing we are concerned with (other than debris) when it comes to tire failures because of the speeds we are running and the length of time at those speeds.1) The display 'rotates' the detailed information for each tire every 4 seconds or so, but the sensors are continuously transmitting data. There are also warning alerts when the tire pressure and temp fall below/rise above a preset (or customized) reading.2) The sensors are 'screwed' into the provided valve stems. There is also a small double sided tape adhesive to secure it to the inside wheel surface. Each sensor weighs only 32grams.3) Since the sensors come with included valve stems, I cannot say for certain whether a shorter valve stem will work. The provided valve stems are all metal, not rubber.It sounds like the 3rd EYE TPMS system meets your criteria to monitor tire conditions. Link to comment Share on other sites More sharing options...
NataSS Inc Posted January 19, 2006 Report Share Posted January 19, 2006 2) The sensors are 'screwed' into the provided valve stems. There is also a small double sided tape adhesive to secure it to the inside wheel surface. Each sensor weighs only 32grams.3) Since the sensors come with included valve stems, I cannot say for certain whether a shorter valve stem will work. The provided valve stems are all metal, not rubber.It sounds like the 3rd EYE TPMS system meets your criteria to monitor tire conditions.Any way I can get a picture of the valve stem? Link to comment Share on other sites More sharing options...
George @ ViVA Posted February 8, 2006 Author Report Share Posted February 8, 2006 NateSS,I'll have a pic of the parts for you this week.Update:We have the 3rd EYE TPMS in stock and ready to ship, if anyone is interested. Link to comment Share on other sites More sharing options...
