NataSS Inc Posted January 19, 2006 Report Share Posted January 19, 2006 Very little as you wont hit 17 psi much at all.Why is that? Wouldnt it go to 17 every time you plant the throttle? I am a little confused here. Link to comment Share on other sites More sharing options...
the underlørd Posted January 19, 2006 Report Share Posted January 19, 2006 Why is that? Wouldnt it go to 17 every time you plant the throttle? I am a little confused here.rookie! Link to comment Share on other sites More sharing options...
javadoc Posted January 19, 2006 Report Share Posted January 19, 2006 Chipped (at least) for over 5yrs now, and I haven't broken anything... yet. Link to comment Share on other sites More sharing options...
steve s Posted January 19, 2006 Report Share Posted January 19, 2006 wow, 85k miles. ok, so not that many miles, but 6 years on ipd chip and 50k miles. not really that much problem. boost leak on those rubber intercooler hoses after 40k miles, but replaced with samco and has been fine Link to comment Share on other sites More sharing options...
JCviggen Posted January 19, 2006 Report Share Posted January 19, 2006 Why is that? Wouldnt it go to 17 every time you plant the throttle? I am a little confused here.Well, between 3500 and 4500-ish rpm you may spike to that...after that its going to fade like a mofo on the stock turbo Furthermore, it hurts top end power to run the turbo at the limit in the mid-range...it really gets out of breath with quite a few revs left.I run an EBC now and the car is significantly quicker with a steady 14 psi all the way than when I was doing 16-17 dropping to 13. Link to comment Share on other sites More sharing options...
PyROTech Posted January 19, 2006 Report Share Posted January 19, 2006 actually you can do more damage vs stock setup if you driving the crap out of the car. But then again you can break stuff with a stock setup driving the crap outta the car. Just remember the more power the more wear and tear. If you treat the car right then you wont have major problems.Its sorta like taking a bra off your girlfriend... she is going to get mad if you just rip it right off each and everytime you take her for a drive. Smooth, not jerking motions will be more rewarding, treating her right and taking care of her will be better in the long run. That doesnt man you cant have harder sex! Link to comment Share on other sites More sharing options...
tomtbone Posted January 19, 2006 Report Share Posted January 19, 2006 Its sorta like taking a bra off your girlfriend... she is going to get mad if you just rip it right off each and everytime you take her for a drive. Smooth, not jerking motions will be more rewarding, treating her right and taking care of her will be better in the long run. That doesnt man you cant have harder sex!hmmmmmm.... must be a Canadian thing eh? but yeah just don't drive the snot out of it every day on your commute, just special occasions. :ph34r: Link to comment Share on other sites More sharing options...
T5INYAFACE Posted January 20, 2006 Report Share Posted January 20, 2006 I have had my jet performance chip for about 8 months 10,000 mile no problem at all. Link to comment Share on other sites More sharing options...
USMC850T Posted January 20, 2006 Author Report Share Posted January 20, 2006 rookie!Why not help him understand why instead of belittling him? Link to comment Share on other sites More sharing options...
PorBleemo Posted January 20, 2006 Report Share Posted January 20, 2006 Why not help him understand why instead of belittling him?That is not the underlord way, my son. Link to comment Share on other sites More sharing options...
Guest 300+_T5R_855 Posted January 20, 2006 Report Share Posted January 20, 2006 I installed the IPD ECU upgrade at 74,000 miles. Shortly thereafter I installed the 17g turbo, about 80,000 miles. (16PSI normally) The car already had the 2 1/2" exhaust. I broke it due to low oil condition at 6000 RPM with 242,900 on the clock. I have the engine torn down and the cylinder walls still show the cross hatch on them and virtually no ridge at the top. Stay on top of the maintenance and you'll enjoy it for a long time to come. Link to comment Share on other sites More sharing options...
kenhoeve Posted January 20, 2006 Report Share Posted January 20, 2006 as for the 17psi 15psi debate,jan is right on as usual. there may be a peak difference, but that is about it. the primary difference between the two is throttle response and a little more aggressive timing maps. i could really tell a difference between the two back to back. get the 17 ya ninny. Link to comment Share on other sites More sharing options...
shaun Posted January 20, 2006 Report Share Posted January 20, 2006 I installed the IPD ECU upgrade at 74,000 miles. Shortly thereafter I installed the 17g turbo, about 80,000 miles. (16PSI normally) The car already had the 2 1/2" exhaust. I broke it due to low oil condition at 6000 RPM with 242,900 on the clock. I have the engine torn down and the cylinder walls still show the cross hatch on them and virtually no ridge at the top. Stay on top of the maintenance and you'll enjoy it for a long time to come.evidence! how refreshing. Link to comment Share on other sites More sharing options...
dreddj Posted January 20, 2006 Report Share Posted January 20, 2006 MTE remap. been about 4 months. so far very smooth, no problems. even dealer didnt pick up anything when they ran a software check.i would say in fact that after tuning, im much more "careful" about driving the car than before tuning. and also, because the car is a lot torquier (and faster) in fact its not that often i get clear stretches of road to go WOT. Link to comment Share on other sites More sharing options...
crc1185 Posted January 21, 2006 Report Share Posted January 21, 2006 I've had ST chip for like 3 or 4 months. I have the 17 psi version, but am running the stock exhaust. I rarely hit 17 psi if ever. Nothing gone wrong yet though! Link to comment Share on other sites More sharing options...
