mikie Posted May 22, 2004 Report Share Posted May 22, 2004 So I'm trying to lead a wire through the firewall from under the hood to drivers side....can't find a hole....I see other wires heading in that direction but then disappears in area i cannot reach!Help me please, I would feel stupid if i have to take it to a garage for something so simple.thanks,Mikie Link to comment Share on other sites More sharing options...
Burgundy_850 Posted May 22, 2004 Report Share Posted May 22, 2004 there's a gray rubbery tube with some 'nipples' that you cut to feed wires through, it comes out in the engine on the driver's side, about 3/4 of the way up. it comes through on the inside behind the kick panel, in where all the relays are. and you'll need to cut a hole in that side too. just feel around for a rubbery thing with nipples ;) Link to comment Share on other sites More sharing options...
mAydAy Posted May 22, 2004 Report Share Posted May 22, 2004 You can also remove the rubber cap, it is ALOT easier to do that. You can cut it and but it back over the wires, since it will not really allow the wires to slide through with it on there. I need to do that, mine are in my center console right now....but other things are more important.-Andy Link to comment Share on other sites More sharing options...
mikie Posted May 22, 2004 Author Report Share Posted May 22, 2004 Alright thanks alot guys, I fed the wire through the black plastic thing that contains a lot of the wires...right below the fuse box (the one attached to my strut bar) into the other fuse box where all the relays are...Finally did the fog light mod!ThanksMikie Link to comment Share on other sites More sharing options...
steve s Posted May 23, 2004 Report Share Posted May 23, 2004 i know it's a little late...but here u go.. under the brake fluid reservior Link to comment Share on other sites More sharing options...
