brick-a-brac Posted January 30, 2006 Report Share Posted January 30, 2006 I've tried searching for this, but cannot seem to find info on the install location for the OEM 4X100W amp in a 98-00 S/V70. I've heard it fits under the passenger seat, but can find nothing to confirm this.P/N = 3533798.Also, I'd love to know a P/N for a harness (if there is one), and where it might connect.Thanks! Link to comment Share on other sites More sharing options...
Aequitas_Veritas Posted January 30, 2006 Report Share Posted January 30, 2006 Amp is between the two seats about a 8-10in behind the radio. You need to remove the carpets and the two side covers to gain access, isnt too hard. Link to comment Share on other sites More sharing options...
connorb850 Posted January 30, 2006 Report Share Posted January 30, 2006 The OEM 4x100W amp was only available in the C70 and is located in the trunk:In the S/V70s, the amp was either under the passenger seat or behind the dash and radio. Link to comment Share on other sites More sharing options...
Aequitas_Veritas Posted January 30, 2006 Report Share Posted January 30, 2006 Hm, but then I also found this, so now I have no ideawell hopefully with all the the volvo parts program pics, you will be able to figure out what you have Link to comment Share on other sites More sharing options...
Big Will Posted January 30, 2006 Report Share Posted January 30, 2006 Hey guys,I've been searching a lot about this too this week. The part # 6816302 is from an 850 R (or the odd pre-98 70 series) I believe and is a 4 X 50 watt amp that mounts behind the radio. You'll need a harness, and bracket to mount it.The amp that SDSU showed in the 2nd diagram part # 9452086 is the amp from a s/V70 that mounts either in the trunk or under the passenger seat (there apparently is a place under the carpet where it can be attached. I believe that is also a 4 X 50 watt amp. Lastly there's the C70 one which is 4 X 100 W but I think that has to mount in the trunk...it seems really big at least.Hope this helped. Link to comment Share on other sites More sharing options...
connorb850 Posted January 30, 2006 Report Share Posted January 30, 2006 In the S/V70, the placement of the amp depends on whether the car has the center speaker or not. If it does have a center speaker, the dolby processor went behind the dash in the old location and the amp went under the seat. Link to comment Share on other sites More sharing options...
Big Will Posted January 30, 2006 Report Share Posted January 30, 2006 ^^Bingo. That's why the in-dash amp that is numbered to work w/ the pre-dolby cars will still fit behind the dash in later (post-97) cars as long as they don't have the Dolby processor...correct? Link to comment Share on other sites More sharing options...
brick-a-brac Posted January 30, 2006 Author Report Share Posted January 30, 2006 Hm, but then I also found this, so now I have no ideawell hopefully with all the the volvo parts program pics, you will be able to figure out what you haveThanks for all the input. I was able to locate the C70 application, but lacked the ability to search for the above image and application. From this, would it be safe to assume that there is an extant harness in the dash that will plug into the harness pictured above?Cheers! Link to comment Share on other sites More sharing options...
