tallahasseegreys Posted May 24, 2004 Report Share Posted May 24, 2004 My tailgate rattles like hell. Most of the clips are broken off, big surprise. The rattle repair kit should come in the mail today.Will the kit be enough to kill all the rattling, or should I peel & seal it as well?If ya'll do recommend peel & sealing, can I do it at a later date after the rattle repair kit is installed...that is, can the panel be easily removed after the rattle repair kit is installed without breaking the new clips?FYI, the rattling is only from normal road driving. I don't need extra rattle protection from bass. Thanks. Link to comment Share on other sites More sharing options...
drPheta Posted May 24, 2004 Report Share Posted May 24, 2004 Yeah, you can peel and seal later, if you're careful, you won't need to replace any clips. Link to comment Share on other sites More sharing options...
tallahasseegreys Posted May 24, 2004 Author Report Share Posted May 24, 2004 Thanks doctor. Link to comment Share on other sites More sharing options...
Guest Guest_shadetek Posted May 24, 2004 Report Share Posted May 24, 2004 The mod kit does not compensate for the thickness of the plastic it has to replace, so pack it out with cloth or foam untill it stops rattling! Link to comment Share on other sites More sharing options...
tallahasseegreys Posted May 24, 2004 Author Report Share Posted May 24, 2004 shadetek - Please elaborate---I'm not sure I follow you. Especially, "The mod kit does not compensate for the thickness of the plastic it has to replace".Thanks! Link to comment Share on other sites More sharing options...
jda2000 Posted May 25, 2004 Report Share Posted May 25, 2004 Make sure you tighten all bolts in that area while you're there, the latch and wiper motor.what he means is: to use felt tape or a piece of foam on the egde that's close to the glass, where the upper clips install. Link to comment Share on other sites More sharing options...
tallahasseegreys Posted May 25, 2004 Author Report Share Posted May 25, 2004 Just installed the repair kit. Took a spin around the 'hood and it's MUCH quieter.Awesome! Link to comment Share on other sites More sharing options...
