Ghost Shadow Posted January 31, 2006 Report Share Posted January 31, 2006 I tried to search and came up with nothing that matches what problem i have.So here it is guys1995 850 GLT N/A 120kDrove home tonight in it, shut car off and then could not get it started again.No dash light (christmas lights), no start, check fuses and they seem ok for checing at 9:30pm in the dark with a flashlight.Cranked the car and nothing, jumped it and nothing(thought maybe dead cell?).Is there a fuse that controlls the dash lights in pos 3.We have only 1 fuse box right in these cars? under the hood. Link to comment Share on other sites More sharing options...
KS_R Posted January 31, 2006 Report Share Posted January 31, 2006 uhh your battery is probably completly dead. TIME FOR A NEW ONE. but that is what i would guess. it doesn't have enough juice to crank over, and it can't power all the lights. when did you last get a new battery? Link to comment Share on other sites More sharing options...
RAzOR Posted January 31, 2006 Report Share Posted January 31, 2006 You said you cranked it. Does that mean it cranks? Or the starter won't even go? Which is it? Link to comment Share on other sites More sharing options...
BtownVolvo Posted January 31, 2006 Report Share Posted January 31, 2006 We have only 1 fuse box right in these cars? under the hood.I don't know about 850's, but X70's have one on the drivers strut and one directly above that, under the windshield wipersIf it doesn't even crank, dead batteryIf it does but won't turn over, could be any number of things Link to comment Share on other sites More sharing options...
GTM2U Posted January 31, 2006 Report Share Posted January 31, 2006 I don't know about 850's, but X70's have one on the drivers strut and one directly above that, under the windshield wipersIf it doesn't even crank, dead batteryIf it does but won't turn over, could be any number of things C'mon guys, I know you mean well but think how a professional would go about this. It's not fair to tell someone to get a new battery or it's a dead battery especially when they said it cranks but doesn't start. Wouldn't it be better to ask what the voltage is? They were asking about fuses and since I'm no 850 Volvo expert I don't know the answer. There are relays, switches, and modules that could cause this problem. Gearshift adjustment and a dozen other possibilities which must be check until you can isolate the problem. Cheers, GTM2U Link to comment Share on other sites More sharing options...
KS_R Posted January 31, 2006 Report Share Posted January 31, 2006 There are relays, switches, and modules that could cause this problem. Gearshift adjustment and a dozen other possibilities which must be check until you can isolate the problem. Cheers, GTM2UWell you may first want to find out if the battery is dead. Sometimes you can try and jump a battery and it still won't start a car, its just dead. This happened with my 525, it would crank for a second but wouldn't start. Tried to jump it and still wouldn't start. We threw a battery in from another car and it started just fine. No reason to get uppity. Link to comment Share on other sites More sharing options...
Guest Guest_whilst_* Posted January 31, 2006 Report Share Posted January 31, 2006 I tried to search and came up with nothing that matches what problem i have.So here it is guys1995 850 GLT N/A 120kDrove home tonight in it, shut car off and then could not get it started again.No dash light (christmas lights), no start, check fuses and they seem ok for checing at 9:30pm in the dark with a flashlight.Cranked the car and nothing, jumped it and nothing(thought maybe dead cell?).Is there a fuse that controlls the dash lights in pos 3.We have only 1 fuse box right in these cars? under the hood.Check battery,and ignition switch. Link to comment Share on other sites More sharing options...
BtownVolvo Posted January 31, 2006 Report Share Posted January 31, 2006 C'mon guys, I know you mean well but think how a professional would go about this. It's not fair to tell someone to get a new battery or it's a dead battery especially when they said it cranks but doesn't start. Wouldn't it be better to ask what the voltage is? They were asking about fuses and since I'm no 850 Volvo expert I don't know the answer. There are relays, switches, and modules that could cause this problem. Gearshift adjustment and a dozen other possibilities which must be check until you can isolate the problem. Cheers, GTM2UOk...your post was just about as helpful as mine Link to comment Share on other sites More sharing options...
Guest Guest_whilst_* Posted January 31, 2006 Report Share Posted January 31, 2006 I tried to search and came up with nothing that matches what problem i have.So here it is guys1995 850 GLT N/A 120kDrove home tonight in it, shut car off and then could not get it started again.No dash light (christmas lights), no start, check fuses and they seem ok for checing at 9:30pm in the dark with a flashlight.Cranked the car and nothing, jumped it and nothing(thought maybe dead cell?).Is there a fuse that controlls the dash lights in pos 3.We have only 1 fuse box right in these cars? under the hood.Check your cables and ends for corrosion,including the ground strap under battery.Then battery and/or ignition switch.(electrical part) Link to comment Share on other sites More sharing options...
Ghost Shadow Posted January 31, 2006 Author Report Share Posted January 31, 2006 Maybe we should FAQ this, there are relays under the hood next to the fuse box that occasionally goes bad. There are three relays under the hood that are normal SPDT relays. Changed all three of them and the car starts normally. Thanks for the goose chase guys Took only 10 minutes to find that problem.thankssteve Link to comment Share on other sites More sharing options...
Guest AlvinL Posted January 31, 2006 Report Share Posted January 31, 2006 Good one and thanks for letting us know. So it's not the ignition switch... It's will be pinned. Link to comment Share on other sites More sharing options...
