MWvolvo850 Posted May 25, 2004 Report Share Posted May 25, 2004 Suspension upgradeI have a Volvo 850 glt and would like to tighten up the stock suspension. My question is where should I begin? Shocks/Struts and a sway bar is what i'm initially going to start with…. I think. This Volvo is my daily driver and I like to drive and corer fast (sometimes) please advise.Thanks Link to comment Share on other sites More sharing options...
jross Posted May 25, 2004 Report Share Posted May 25, 2004 The sways will make the biggest difference, followed by the struts/shocks (maybe you should think about springs too or replacing all three with KWs). Sounds like you're right on track! Link to comment Share on other sites More sharing options...
freeskier8585 Posted May 25, 2004 Report Share Posted May 25, 2004 KW's!!!! Link to comment Share on other sites More sharing options...
t5mtl Posted May 25, 2004 Report Share Posted May 25, 2004 you can forget about ipd bars thay are backorder till july Link to comment Share on other sites More sharing options...
MWvolvo850 Posted May 25, 2004 Author Report Share Posted May 25, 2004 Yea - bummer on the IPD swaybar being on back order until July. When I replace the shocks/struts - will I need to replace the shock/strut mounts? Link to comment Share on other sites More sharing options...
V Tuning 850 Posted May 25, 2004 Report Share Posted May 25, 2004 Some people suggest you do, but you don't have to, but it is a good idea, just to upgrade everything. Link to comment Share on other sites More sharing options...
freeskier8585 Posted May 25, 2004 Report Share Posted May 25, 2004 id replace my strut bearings too, mine squeek Link to comment Share on other sites More sharing options...
swimboig83 Posted May 25, 2004 Report Share Posted May 25, 2004 when the strut bearing squeak does it sound like a chirp from the strut tower? thats what i am getting from the drivers side strut when i go over bumps or barke quick. Link to comment Share on other sites More sharing options...
shurgen Posted May 26, 2004 Report Share Posted May 26, 2004 Maybe you don't have to replace the sway bar if bushings are not vulcanized to the bar. On older cars they are not. If you can, remove one of your wheels and take a look if bushing is vulcanized to the bar. I just replaced bushings on my 93 850GLT that i got for $10/pair from fcpgroton. That way you won't have to wait on ipd or spend money on the sway bar at all. Link to comment Share on other sites More sharing options...
jross Posted May 26, 2004 Report Share Posted May 26, 2004 That way you won't have to wait on ipd or spend money on the sway bar at all.The iPd bars are alot bigger (diameter) than stockers, so the car handles better. Link to comment Share on other sites More sharing options...
mAydAy Posted May 26, 2004 Report Share Posted May 26, 2004 I've got a 1996 850R with Bilsteins, Spax springs and iPD bars. The bars made a huge difference. Something else not too often thought about around here that probably made the biggest difference of it all -- cranking up the wheels to maximum negative camber. Grip tripled from that, allowing everything to be used more efficiently. 850's camber is usually wonky, and eats outter tire edges, this will fix that and increase grip, alot.-Andy Link to comment Share on other sites More sharing options...
jross Posted May 26, 2004 Report Share Posted May 26, 2004 Yours eats outside? Mine eats inside.. Anyknow know if it's possible/ difficult to do alignment one's self? Link to comment Share on other sites More sharing options...
freeskier8585 Posted May 26, 2004 Report Share Posted May 26, 2004 when the strut bearing squeak does it sound like a chirp from the strut tower? thats what i am getting from the drivers side strut when i go over bumps or barke quick.mine sound like a little birdAnyknow know if it's possible/ difficult to do alignment one's self?you need a 50,000 dollar machine, but its easy to do if you have it :P Link to comment Share on other sites More sharing options...
850 Stylzz Posted May 26, 2004 Report Share Posted May 26, 2004 Yours eats outside? Mine eats inside.. Anyknow know if it's possible/ difficult to do alignment one's self?Imfreakinpossible. Or so I hear. Link to comment Share on other sites More sharing options...
steve s Posted May 26, 2004 Report Share Posted May 26, 2004 ipd bars are 25mm f and 22mm r... volvo bars are anywhere from 21~19 mmi've got more wear on the outside edge of the tire too...camber is at -0.5 front... i was thinking of getting hr's triple c camber adjustment bolts... Link to comment Share on other sites More sharing options...
