Just Chipped Car, Boosting Only 12 Of 17 Psi
USMC850T
Ok but where do I go to make the wastegate adjustment, top or bottom, and which way to turn.
take off the heatshield, and you'll see the Rod coming from the actuator to the valve. take off the pin, take the rod off of the valve, loosen the jam nut, and then tighten it 2 turns or so like Jan said. Retighten the jam nut, and put it all back the way it went apart.
edit.. gregg beat me to it.
  • Replies 58
One entry found for concise.
Main Entry: con·cise audio.gif
Pronunciation: k&n-'sIs
Function: adjective
Etymology: Latin concisus, from past participle of concidere to cut up, from com- + caedere to cut, strike
1 : marked by brevity of expression or statement : free from all elaboration and superfluous detail
ZING
If you're not interested in the T with the BOV kit... this place has great pricing.
http://www.9secondracing.com/cgi-bin/search.cgi?kws=volvo
OT just for a second. How come the blue hoses are 64$ cheaper then the Red and Black ones?
That hose Joseph showed is pretty crucial. That crack typically limits boost to 10-12 psi...
You mentioned you checked charge hoses, but make sure that the base of the T coming off of the hose before the throttle body is not cracked, as I have had 4-5 of those crack on my cars, two of them brand new from the dealership. It happens :lol: Not visible upon a brief inspection, have to move that T hose around a bit to see.
Aside from that, could be leaking CBV, could be a couple other things as well... You won't drop that much boost from vacuum lines though I'm pretty sure.
Tighten the wastegate a bit and see where that gets you :)
The wastegate was the culprit. I tightened it down 2 full turns which has me around 15psi right now, hopefully tomorrow I'll get a chance to get back in there and do another 1.5 - 2 turns to let the boost reach its intended level. I took a bunch of pictures while I was doing it so I could make a guide for those who have never done it before. It was a hell of a lot easier to do once I took of the charge air line leaving the compressor section. I had to have my younger brother help cause I didn't have enough hands to hold the tools and light at the same time.
