ncst8wuf Posted February 19, 2006 Report Share Posted February 19, 2006 How do I remove the old Air Mass Sensor from the hose once I have the hose clamp removed. It will slide around, but I can't get it out of the hose.Thanks Link to comment Share on other sites More sharing options...
wills Posted February 19, 2006 Report Share Posted February 19, 2006 I just pull very hard and carefully. It's a tight fit. :angry: Link to comment Share on other sites More sharing options...
ncst8wuf Posted February 21, 2006 Author Report Share Posted February 21, 2006 Thanks wills, I finally got it out. Now I have 2 additional questions.1. Will an Air Mass Sensor from a 99 V70 turbo work on a 2000 v70 XC?2. I've already replaced the OEM with said 99 AMM and it is still tripping to P1171, could there be another cause?Thanks Link to comment Share on other sites More sharing options...
the underlørd Posted February 21, 2006 Report Share Posted February 21, 2006 Thanks wills, I finally got it out. Now I have 2 additional questions.1. Will an Air Mass Sensor from a 99 V70 turbo work on a 2000 v70 XC?2. I've already replaced the OEM with said 99 AMM and it is still tripping to P1171, could there be another cause?Thanks99 should work on 00 (thanks sean... 100% sure..) Link to comment Share on other sites More sharing options...
WhiteT5 Posted February 21, 2006 Report Share Posted February 21, 2006 Just checked the part numbers... they're the same. Link to comment Share on other sites More sharing options...
ncst8wuf Posted February 21, 2006 Author Report Share Posted February 21, 2006 thanks guys. So either the replacement AMM is also bad, or it's probably a vacuum leak?I've just had it in to my mechanic and he checked the vacuum lines. What is the likelyhood he may have missed one? Link to comment Share on other sites More sharing options...
the underlørd Posted February 21, 2006 Report Share Posted February 21, 2006 thanks guys. So either the replacement AMM is also bad, or it's probably a vacuum leak?I've just had it in to my mechanic and he checked the vacuum lines. What is the likelyhood he may have missed one?is the MAF new? doubtful a new one is faulty.. As for the skills of your mechanic.... i dunno.. you might want to replace them all yourself, with silicone ones, there are kits available for pretty cheap here on the website.. takes a couple hours or so. Link to comment Share on other sites More sharing options...
ncst8wuf Posted February 21, 2006 Author Report Share Posted February 21, 2006 No, it's not a new MAF. I have a 30 day warranty on the MAF.How long should it take to reset the CEL, once I put the new one in? Link to comment Share on other sites More sharing options...
