tallahasseegreys Posted February 21, 2006 Report Share Posted February 21, 2006 What up with these volvo wiper arms? I've never owned a car that required constant tightening of of these nuts!!!!Is there any reason I can't/shouldn't put a lock washer between the arm and the 13mm nut? If I can, what type of lock washer...star, lockring....??? Link to comment Share on other sites More sharing options...
the underlørd Posted February 21, 2006 Report Share Posted February 21, 2006 What up with these volvo wiper arms? I've never owned a car that required constant tightening of of these nuts!!!!i've never heard of anyone else having any problems with then. are you like constantly using them? Link to comment Share on other sites More sharing options...
tallahasseegreys Posted February 21, 2006 Author Report Share Posted February 21, 2006 Am I constantly using my wipers? Only when it's raining! Link to comment Share on other sites More sharing options...
beachnut Posted February 21, 2006 Report Share Posted February 21, 2006 Are you sure the splines on the motor shaft or the arms aren't just worn out? Link to comment Share on other sites More sharing options...
merlin390 Posted February 21, 2006 Report Share Posted February 21, 2006 Call the guys at FCP and get another arm I had the same problem and attempted the same fix and finally I replaced the arm and all is well. Link to comment Share on other sites More sharing options...
Guest AlvinL Posted February 21, 2006 Report Share Posted February 21, 2006 I remember this happening on my former 850. The arm's splines wore out and kept slipping even after the nut was tightened all the way down until the nut eventually bottomed out. You can buy yourself more time by using a washer between the nut and arm that has a larger inside diameter than the wiper's center spline. Link to comment Share on other sites More sharing options...
