dragon17 Posted February 25, 2006 Report Share Posted February 25, 2006 run.. run far far away from a 1999 S80...Kevin, stop spreading false rumors! They are not all bad. The passenger's illuminating light in my car is out but its somewhat complicated to replace it. You need to first remove the stock stereo unit (takes patience and some effort). Then, unclip the a/c unit (lower) and the little bulbs are located behind where all of the wiring is. Link to comment Share on other sites More sharing options...
Aequitas_Veritas Posted February 25, 2006 Report Share Posted February 25, 2006 Kevin, stop spreading false rumors! They are not all bad. The passenger's illuminating light in my car is out but its somewhat complicated to replace it. You need to first remove the stock stereo unit (takes patience and some effort). Then, unclip the a/c unit (lower) and the little bulbs are located behind where all of the wiring is.on an 850 the same task took me 10min and only involves pulling off the lense. why do you guys like the s80s again? Link to comment Share on other sites More sharing options...
dragon17 Posted February 27, 2006 Report Share Posted February 27, 2006 why do you guys like the s80s again?C'mon, stop playing. I saw you eyeballing my S80 at the meet. :P Link to comment Share on other sites More sharing options...
the underlørd Posted February 27, 2006 Report Share Posted February 27, 2006 Kevin, stop spreading false rumors! They are not all bad. The passenger's illuminating light in my car is out but its somewhat complicated to replace it. You need to first remove the stock stereo unit (takes patience and some effort). Then, unclip the a/c unit (lower) and the little bulbs are located behind where all of the wiring is.ok, they're not all bad, but most of 'em are. Link to comment Share on other sites More sharing options...
dragon17 Posted February 27, 2006 Report Share Posted February 27, 2006 ok, they're not all bad, but most of 'em are.Thank you for the clarification. As long as you agree that not all. Link to comment Share on other sites More sharing options...
mlanctot Posted February 27, 2006 Report Share Posted February 27, 2006 So get back to the question, anyone have knowledge of getting into the dash to change troughs little bulbs?Yes it is the linkage to the sway bar. Bad nylon at the joint. Buy a couple of them every 30K, common problem on a lot of Volvos.Problems with S80T6s often originate with the mechanics. Have dealt with two dealerships. One very good, one not soo good or maybe just a poorer mechanic. This isn’t a Chevy. Link to comment Share on other sites More sharing options...
