bigjohnsons34 Posted February 26, 2006 Report Share Posted February 26, 2006 hi, i have a 2000 s40 and the check engine light came on, so i took it and had the car scaned and found ( code p0014 ) camshaft position actuator b - bank 1 timing over advan. and ( code po128 ) coolant temp below thermostat regulating temp...what does all this mean.. thanks for your help Link to comment Share on other sites More sharing options...
starfish Posted February 27, 2006 Report Share Posted February 27, 2006 The ECM found a fault with the camshaft position on engine start up. Possibilities could be low or worn out engine oil, low oil pressure, clogged oil feed lines, a faulty camshaft reset valve or a faulty CVVT unit. Your engine thermostat may be stuck open and the engine is not reaching operating temp quickly enough. There was also a software update that might help this concern if the T/stat and ECT sensor are ok. Link to comment Share on other sites More sharing options...
MrWinkey Posted February 28, 2006 Report Share Posted February 28, 2006 The ECM found a fault with the camshaft position on engine start up. Possibilities could be low or worn out engine oil, low oil pressure, clogged oil feed lines, a faulty camshaft reset valve or a faulty CVVT unit. Your engine thermostat may be stuck open and the engine is not reaching operating temp quickly enough. There was also a software update that might help this concern if the T/stat and ECT sensor are ok.Sounds good to me...I would change the oil if it hasn't been done in awhile and clear codes and see what returns .....Unless you just recently had a timing belt done....then that's a whole diffrent story? Link to comment Share on other sites More sharing options...
