tallahasseegreys Posted May 29, 2004 Report Share Posted May 29, 2004 On the back of the "flap" that covers the fuel cap, it gives 2 different pressures to run in the tires. One is 36 psi in the front and 41 psi in the rears. This is "recommended for fuel economy."The other is 32 in the front and 31 in the rears...quite a difference.What's the deal with this? I currently have them running at the fuel economy settings. What do you guys run?The tires on my base 850 are 195/60 VR15's. Thanks. Link to comment Share on other sites More sharing options...
Bay13 Posted May 29, 2004 Report Share Posted May 29, 2004 I run my tires at 40psi front and rear, good for tire wear, not worried about ride comfort from the tires, if I was I'd have tires with a bigger side wall and stock shock and struts on the car.In the shop when doing a service I set all the tires at 38psi. Most are not low profile tires. Link to comment Share on other sites More sharing options...
XtremePsionic Posted May 29, 2004 Report Share Posted May 29, 2004 If you don't pull any Gs in corners, you can go ahead and use 32-35psi. Don't go too low tho, or handling could become dangerous.You have 15" tires, with a lower pressure the ride will be quite comfortable. For best tirewear/performance, 38 or so is pretty good. Link to comment Share on other sites More sharing options...
DEWFPO Posted May 29, 2004 Report Share Posted May 29, 2004 The lower pressure recommendation is the 'comfort' setting.DEWFPO Link to comment Share on other sites More sharing options...
tallahasseegreys Posted May 29, 2004 Author Report Share Posted May 29, 2004 Thanks. I'll try 38 front and rear. Right now with 41 rear it feels like my rear tires are ROCKS. Link to comment Share on other sites More sharing options...
ziddey Posted May 29, 2004 Report Share Posted May 29, 2004 hmm. my rear tires are practically new (left was last year, right is today). my fronts are about 3-4 yrs old. needlesstosay, they are almost gone (probably another year). what good do back tires have? by that, i mean it would be much more advantageous for me at this point to put the new tires up front and stick the worn ones out back? i mean, my car is fwd anyway. im thinking i can pull in at least 2 more years out of those ones. Link to comment Share on other sites More sharing options...
James A Sousa Posted May 30, 2004 Report Share Posted May 30, 2004 I keep the ratios between the pressures that volvo recommendsF - 36 R - 41orF - 35 R - 39orF - 34 R - 36orF - 33 R - 34orF - 32 R - 31In the 855R we run F - 35 R - 39 around town and F - 36 R - 41 when the car is loaded for a trip.In our 855 we run F - 34 R - 36 around town and F - 36 R - 41 when loaded. Link to comment Share on other sites More sharing options...
ziddey Posted May 30, 2004 Report Share Posted May 30, 2004 hmm. my toyo tires say max pressure 50, rec 44 or something like that Link to comment Share on other sites More sharing options...
jda2000 Posted May 30, 2004 Report Share Posted May 30, 2004 I keep mine at 35 psi all around, easier to remember and the ride is not that harsh. Link to comment Share on other sites More sharing options...
sam&jake Posted May 30, 2004 Report Share Posted May 30, 2004 I used to vary between the two Volvo recommended pressures. I'd pump it up to 36/41 for family hauls with two kids, two dogs, tons of luggage, plus a roof rack full of gear. Of late, I just keep it at 36/41. I don't notice much ride difference any more, plus I can't complain about the wear on my tires. Over 60k and lots of tread left (Michelin X-one's). Link to comment Share on other sites More sharing options...
