banksie312 Posted March 9, 2006 Report Share Posted March 9, 2006 so im going to be honestive put off putting in my gauges because of the temperature but now i dont have that excuse and realized...holy crap i have no clue how to do thisfor reference i am installing megan racing Turbo/Vac and A/F gaugesthe turbo/vac gauge doenst really look that hardi did have a question on what it says about the orange and red wiresfor the orange wire it says "Connect To 12V lighting source"and the red wire says "12V Ignition Switch (+)"does that mean that the orange wire connects to the interior light dial (it has 3 options, headlights interiors off; no headlights interiors on; and then headlights interiors on)and then the red one goes where?for the A/F gauge...i have no clueit has a really complicated diagram but the best thing i can describe is the black wire connects to the engine groundthe green wire connects to the O2 sensor signalthe red wire connects to...and then it has the complicated diagramheres another problem i have..i read a thing about drilling a hole throught the firewall via the plate for the transmission or something...i have a manual and that is being occupied...i cant seem to find my firewall passthrough and have read that it is quite smallcan someone direct me to another post or help me out? (yes i did search for like 20 minutes to try and find something but the firewall is a frequent topic that is mostly solved by the hole for the tranny...theres my problem)will what needs to fit through, fit through if i can find it?with correct instructions...is it possible to do in 2 hours...give or take a littleim not an idiot but im no pro (as you can see by my post)thanks for all of the help guys Link to comment Share on other sites More sharing options...
the underlørd Posted March 9, 2006 Report Share Posted March 9, 2006 the passthrough is underneath the fuse box.. it's got a funky lil rubber cap on the end of some corregated tubing.. Link to comment Share on other sites More sharing options...
banksie312 Posted March 9, 2006 Author Report Share Posted March 9, 2006 the passthrough is underneath the fuse box.. it's got a funky lil rubber cap on the end of some corregated tubing..ok and i guess that i just see where it comes out on the interior side?ANY INFO OR HELP ON ANY PART IS NEEDED...thanks Link to comment Share on other sites More sharing options...
banksie312 Posted March 11, 2006 Author Report Share Posted March 11, 2006 bump...i actually got VS instructions on how to install the boost gauge...im dumbbut i really really need help with the A/F gaugewhere is the oxygen sensor?do i have a non heated or a heated oxygen sensor?and help is greatly appreciated...please help! Link to comment Share on other sites More sharing options...
yangotang Posted March 11, 2006 Report Share Posted March 11, 2006 where is the oxygen sensor?do i have a non heated or a heated oxygen sensor?and help is greatly appreciated...please help!Follow your downpipe to the exhaust and ye shall find two heated oxygen sensors. Link to comment Share on other sites More sharing options...
banksie312 Posted March 11, 2006 Author Report Share Posted March 11, 2006 Follow your downpipe to the exhaust and ye shall find two heated oxygen sensors.thanksive been trying to find the passthrough on the firewall and the pic that ive been using to locate this is from the VS tutorial on how to install the VDO boost gaugei cant seem to find iti have a v70 MANUAL...help me Link to comment Share on other sites More sharing options...
USMC850T Posted March 12, 2006 Report Share Posted March 12, 2006 You can T the boost gauge into the stock line. That's how mine is setup. Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted March 12, 2006 Report Share Posted March 12, 2006 Do not splice into the stock o2 sensor, please, don't do it.If you are going to use that useless narrowband a/f gauge, commonly referred to as a light show, at least pick up a single wire o2 sensor. http://www.atpturbo.com/Merchant2/merchant...tegory_Code=SNS It makes install of an A/F gauge much easier, just ground, power, and tap the single wire off the o2 gauge. on my s70 t5m the firewall passthrough was pretty much in the same spot. , down there underneath the fuse box, just feel around for that big rubber piece with all the nipples on it. Link to comment Share on other sites More sharing options...
gdizzle Posted March 12, 2006 Report Share Posted March 12, 2006 thanksive been trying to find the passthrough on the firewall and the pic that ive been using to locate this is from the VS tutorial on how to install the VDO boost gaugei cant seem to find iti have a v70 MANUAL...help meYou found it! Now take the rubber boot off, then go into the cabin of the car on the driverside, remove the upper kick panel under the dash the pass through comes in just behind the relay panel in the upper left hand corner. Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted March 12, 2006 Report Share Posted March 12, 2006 You found it! Now take the rubber boot off, then go into the cabin of the car on the driverside, remove the upper kick panel under the dash the pass through comes in just behind the relay panel in the upper left hand corner. That's a picture off this site (chuck's tutorial), not one banksie took. Link to comment Share on other sites More sharing options...
banksie312 Posted March 12, 2006 Author Report Share Posted March 12, 2006 alright well i was able to go ahead and find it...it took a lot of trouble finding it because theres so much (and i have a EST air intake with heat shield blocking the way)ends up the tube for the gauge was too short...i also have a problem with the T...i dont know how to hook it upi see where you are supposed to connect it to the tree...but i dont understand howthe HOW To confused me Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted March 12, 2006 Report Share Posted March 12, 2006 Just cut the rubber vacuum hose in half and put it inside the cut, then run the left over part of the T to your boost gauge. Link to comment Share on other sites More sharing options...
