Karlson Posted March 16, 2006 Report Share Posted March 16, 2006 how about axle? do we need to buy manual transmision axle or automatic works? Link to comment Share on other sites More sharing options...
yangotang Posted March 16, 2006 Report Share Posted March 16, 2006 how about axle? do we need to buy manual transmision axle or automatic works?Refer to post #6.The manual ones are thicker from what i've heard. Link to comment Share on other sites More sharing options...
Zappo Posted March 16, 2006 Report Share Posted March 16, 2006 how about axle? do we need to buy manual transmision axle or automatic works? Autos will work just fine. There is a visual difference between the turbo and non-turbo axles, but a lot of places don't even sell the non-turbo ones anymore since they all fit. Link to comment Share on other sites More sharing options...
trance42 Posted March 17, 2006 Report Share Posted March 17, 2006 Parts list from my sigM56(h or l) or M59Brake/clutch pedal assemblymaster cylinderslave cylinder ***Buy Newhard line hose that connects the master/slave cylindershift box/shifter/shift bootmanual center console black piecemanual shifter linkagethrowout bearing ***Buy Newthrowout forkpilot bearing ***Buy Newmanual driveshafts **Realized the auto ones work fine850 flywheelclutch diskpressure platei havnt put my console back togather completly. what is the manual center console black piece.what is The shift box? and i guess i should know this but what the pilot bearing is. hopefully its not something i left out. Link to comment Share on other sites More sharing options...
Ghost Shadow Posted March 17, 2006 Report Share Posted March 17, 2006 from my sig, you will see a link to the play by play when i did my swap!Parts list from my sigM56(h or l) or M59Brake/clutch pedal assemblymaster cylinderslave cylinder ***Buy Newhard line hose that connects the master/slave cylindershift box/shifter/shift bootmanual center console black piecemanual shifter linkagethrowout bearing ***Buy Newthrowout forkpilot bearing ***Buy Newmanual driveshafts **Realized the auto ones work fine850 flywheelclutch diskpressure plate Link to comment Share on other sites More sharing options...
AnthonyR Posted March 17, 2006 Report Share Posted March 17, 2006 Auto driveshafts will workI have the single mass NA spec clutch kitthe center console black piece has a smaller opening with bumps for use with the shift boot and holding it on properly, not overly needed. Link to comment Share on other sites More sharing options...
Karlson Posted March 17, 2006 Report Share Posted March 17, 2006 Anthony, did u ever take pics of your swap? Link to comment Share on other sites More sharing options...
bloc Posted March 17, 2006 Author Report Share Posted March 17, 2006 i havnt put my console back togather completly. what is the manual center console black piece.what is The shift box? and i guess i should know this but what the pilot bearing is. hopefully its not something i left out."shift box" is the actual shifter that you install in the center console. center console black piece would be the trim surrounding that. pilot bearing is a little bushing that goes into the end of the crank shaft to stabilize the input shaft from the transmission. if you didnt put this in, you need to. some cars come without a pilot bearing, whether or not it's needed depends on the transmission design. on the volvos, apparently it's needed. Link to comment Share on other sites More sharing options...
AnthonyR Posted March 17, 2006 Report Share Posted March 17, 2006 Anthony, did u ever take pics of your swap?Yes I took lots of pics, just never got around to resizing and processing them for the internet. Link to comment Share on other sites More sharing options...
Zappo Posted March 17, 2006 Report Share Posted March 17, 2006 Yes I took lots of pics, just never got around to resizing and processing them for the internet. Slacker. My biggest issue was the flywheel, but if I can just use the NA one, all should be good. Link to comment Share on other sites More sharing options...
bloc Posted March 17, 2006 Author Report Share Posted March 17, 2006 yeah the NA flywheel makes this a whole lot easier and cheaper. i was ready to drop 400 bux on a new turbo flywheel.Justin Link to comment Share on other sites More sharing options...
AnthonyR Posted March 18, 2006 Report Share Posted March 18, 2006 plus the NA is single mass, which doesn't have any of the supposed issues of mis-installation that the dual mass has. Link to comment Share on other sites More sharing options...
Zappo Posted March 19, 2006 Report Share Posted March 19, 2006 Do you need the special alignment tool for the single mass? Link to comment Share on other sites More sharing options...
bloc Posted March 19, 2006 Author Report Share Posted March 19, 2006 a regular clutch disk alignment tool should be all you need.personally i dont like using those things. i've always been able to eyeball it to a more accurate state than the tools anyway. Link to comment Share on other sites More sharing options...
AnthonyR Posted March 19, 2006 Report Share Posted March 19, 2006 He's correct I used a screwdriver and my eyes to align. I had the volvo tool and tried to use it to align, but it was much easier to align by eyesight. It's the dual mass that you need the spring compressor tool. Link to comment Share on other sites More sharing options...
