slarti Posted June 1, 2004 Report Share Posted June 1, 2004 My dad's 95 850 turbo with about 170K miles on it started making some strange noise that he was unable to discribe to me. He pulled over and shut off the car. We checked the oil and it was low, after adding oil we tried to start it and it just wouldn't catch.I checked all the fuses, and checked the fuel rail to for fuel, both ok.But, when I turn the key to the 2nd position, I don't hear the pumping/pressurizing sounds I have when I turn the key on my 96 850R. Could this be the cause of the problem?Any suggestions would be appreciated. Thanks All. Link to comment Share on other sites More sharing options...
Bay13 Posted June 2, 2004 Report Share Posted June 2, 2004 Take off the oil fill cap and crank the engine to see if you can see the cams turning over, if you can't you have a broken Timing belt and need a head job at the min. Link to comment Share on other sites More sharing options...
slarti Posted June 2, 2004 Author Report Share Posted June 2, 2004 Thanks Rich.Edit: I have checked the cams and they are moving, what else should I check? Link to comment Share on other sites More sharing options...
rsmigel Posted June 2, 2004 Report Share Posted June 2, 2004 Do you have spark? Link to comment Share on other sites More sharing options...
slarti Posted June 2, 2004 Author Report Share Posted June 2, 2004 Yes, I've got spark. Link to comment Share on other sites More sharing options...
slarti Posted June 3, 2004 Author Report Share Posted June 3, 2004 BumpNeed help fast, my dad stole my car till his is fixed. :o Link to comment Share on other sites More sharing options...
gronberg Posted June 3, 2004 Report Share Posted June 3, 2004 When you turn the ignition on are all the lamps lighting up on the dashboard?No error codes?Try starting it in N. Link to comment Share on other sites More sharing options...
slarti Posted June 3, 2004 Author Report Share Posted June 3, 2004 I've got codes 435 and 436, but those have been there for a while. I didn't think that the O2 sensor codes would prevent it from starting.All the dash light are on.I've tried starting it in Neutral. No joy. Link to comment Share on other sites More sharing options...
Bay13 Posted June 3, 2004 Report Share Posted June 3, 2004 Compression would be nice to know if you have the correct compression. Check the wires on the positive terminal of the battery and make sure none of them are broken or very dirty. Link to comment Share on other sites More sharing options...
rsmigel Posted June 4, 2004 Report Share Posted June 4, 2004 Will the car start with "instant-start" sprayed into the intake past the air filter? Link to comment Share on other sites More sharing options...
rsmigel Posted June 4, 2004 Report Share Posted June 4, 2004 Oops, I'd pull the plugs and do a visual on them too. Do they look OK? Link to comment Share on other sites More sharing options...
slarti Posted June 4, 2004 Author Report Share Posted June 4, 2004 I don't have the tools to check compression, but I did check the plugs and they are a little dirty but not bad. I had just replaced them about 5K miles ago.I haven't tried the instant-start stuff, is that stuff ok for the MAF?I'm wondering if the lack of noise when I turn the key to the "on" position is something to be concerned about. On my 96 850R I get a bit of noise when I turn the key, sounds like a pump or motor, no such noise on the 95 850 right now, but I'm sure I've heard it on this car too.Any ideas? Link to comment Share on other sites More sharing options...
Guest Guest Posted June 4, 2004 Report Share Posted June 4, 2004 Replace fuel pump relay 103 in the fuse box.Remove screws and the whole lid to find it.Giving it a tap may be a temporary cure. Link to comment Share on other sites More sharing options...
Guest Guest_cfd Posted June 4, 2004 Report Share Posted June 4, 2004 check the small red wire at poss terminal on battery Link to comment Share on other sites More sharing options...
rsmigel Posted June 4, 2004 Report Share Posted June 4, 2004 Run the instant-start and let's get the "fuel" question answered. I've used it a few times on my '94 w/o damage to the MAF sensor. If it fires up, then dies, then we know your problem is fuel related. Link to comment Share on other sites More sharing options...
