Matts 850 GLT Posted March 16, 2006 Report Share Posted March 16, 2006 HiI just repaired my passenger side heated seat with a new thermostat. But my drivers side still not working.Have put a new thermostat on it and no heat.......I checked the wiring under the seat but wasn't sure which color is for what.If anyone has a wiring diagram for heated seat please can I see it??Much appreciationMatt Link to comment Share on other sites More sharing options...
Matts 850 GLT Posted March 16, 2006 Author Report Share Posted March 16, 2006 DUH Just wanted to let you know I hit search and came up with this. ThanksMatt Link to comment Share on other sites More sharing options...
coolwheels Posted March 27, 2006 Report Share Posted March 27, 2006 Here's another diagram of the seat heaters. The connecter link will show what the various connectors under the seat look like. The table for that is below.C/CE Connector, 2-pin, heated front seat, left C/CF Connector, 2-pin, heated front seat, left C/CG Connector, 2-pin, heated front seat, right C/CH Connector, 2-pin, heated front seat, right 3/91 Switch, heated front seat, left 3/92 Switch, heated front seat, right 7/43 Thermostat, left front seat 7/44 Thermostat, right front seat 9/3 Backrest heater pad, left front seat 9/4 Backrest heater pad, right front seat 9/5 Seat heater pad, left front seat 9/6 Seat heater pad, right front seat 11/26 Fuses 24/1 ConnectorInstrument panel harness - firewall harness 24/2 ConnectorEngine compartment harness - firewall harness 24/3 ConnectorFirewall harness - left door sill harness 24/4 ConnectorFirewall harness - right door sill harness 24/7 Connector, 14-pin Firewall harness - tunnel harness 24/21 Connector, 6-pinLeft door sill harness - left front seat 24/22 Connector, 6-pinRight door sill harness - right front seat 31/15 Ground point, A-pillar passenger side 31/44 Ground point, engine compartment (ground point, battery - body) 31/47 Ground point, left cross member 31/48 Ground point, right cross member Link to comment Share on other sites More sharing options...
