ABOSSV70R Posted March 21, 2006 Report Share Posted March 21, 2006 I am in the search of a 00 V70 R and alredy have pleanty of gear for the ICE side on my future car.the only thing is that i am thinking of keeping the factory deck for a bit to speand $$ on other performance parts. Now my question is that i have a Sound Stream D'Artagnan 5.1 amp D'Artagnan 5.1 this is a awsome 5.1 amp that has 6 outputs. I want to use the factory deck and not have to use a hi to low pass converter. i have seen amp help with older radio but none on the 5.1 radio that comes in the V70 R.if not i will have to buy a new deck and speand cash that i would rather speand on the performance parts.oh tell me what you think of the amp. Link to comment Share on other sites More sharing options...
the underlørd Posted March 21, 2006 Report Share Posted March 21, 2006 read the stickied threads. Link to comment Share on other sites More sharing options...
ABOSSV70R Posted March 21, 2006 Author Report Share Posted March 21, 2006 Yeah i have read the tread but the stock unit in a V70 R would have 3 pairs of out puts. 1 pair L/R Front 1 pair L/R Rear and 1 pair Center/Sub out put and would like to know if this is possible on the back of the factory unit or am i going to need 3 hi/low adapters.thanks for the help.by the way if anyone has a image of the back of the radio of a V70 with suround out put it would be great.thanks again Link to comment Share on other sites More sharing options...
the underlørd Posted March 21, 2006 Report Share Posted March 21, 2006 you're looking for the back of a SC-901. fyi. pretty sure i've seen some pics floating around.. Link to comment Share on other sites More sharing options...
ABOSSV70R Posted March 22, 2006 Author Report Share Posted March 22, 2006 Thanks for the sugestion, but i have looked and googled and searched other forums but no help. I know the SC-901 does not have a sub out, but i thought of converting the center control to control the sub volume. and creating a mono signal for the center controlled by the front channel. The biggist thing i need to see the rear of the radio SC901 and a wire output diagram if possible if not i will spend time with a multi-meter when i buy my V70 R. Link to comment Share on other sites More sharing options...
ABOSSV70R Posted March 22, 2006 Author Report Share Posted March 22, 2006 I forgot to mention that i will have a great front stage once i am done making kick panels for the Boston Acoustics 6.53 speakers that i have. they a 6 speakers a pair of 1 ", 4" and 6 1/2" speakers with a great cross overBoston Acoustics 6.53 Systemi will also to 6.5 pro in the rear and 1 12 kicker L7 now the only thing is to find a good center channel. Link to comment Share on other sites More sharing options...
Jacob Posted March 22, 2006 Report Share Posted March 22, 2006 I am pretty sure that the V70R uses the HU series radios and no the SC series radios. I could be wrong. Try a seach for HU613 Link to comment Share on other sites More sharing options...
gdizzle Posted March 22, 2006 Report Share Posted March 22, 2006 I am pretty sure that the V70R uses the HU series radios and no the SC series radios. I could be wrong. Try a seach for HU613it's a '00 V70R...... Link to comment Share on other sites More sharing options...
Kibim Posted March 22, 2006 Report Share Posted March 22, 2006 No, it's a 2000 V70R, so will be SC series. There are pics of the SC-901 pin outs. There is however, no centre/sub out, only 4 ch on the din plug. I have the pin-outs at home i'm sure. I've made up adapter cables too, that run low level inputs into an ICE amp. My suggestion would be to use a 4ch amp to run the door and rear deck speakers, take a loop out of that into a sub amp, and run the centre speaker off the HU. The centre speaker gets power and signal off the HU, and is itself an amplified speaker. It plugs into the *surround* multi-pin din connector on the back, for which i do not have, nor can find pinouts. Many people will tell you just to get a new HU, as the stock system isn't very flexible, but with enough work, it can be made to do what you want it to do. Link to comment Share on other sites More sharing options...
Jacob Posted March 22, 2006 Report Share Posted March 22, 2006 No, it's a 2000 V70R, so will be SC series.Whoops, did not see the 2000! :ph34r: Link to comment Share on other sites More sharing options...
ABOSSV70R Posted March 22, 2006 Author Report Share Posted March 22, 2006 Guys thanks for all of the feed back and info but i have not been able to find a image of the sc 901 radio. IE the rear of the radio Link to comment Share on other sites More sharing options...
