red c70 Posted March 22, 2006 Report Share Posted March 22, 2006 Has anyone else here with the ht2.3 ltr or even the lt turbo engine had any problems with the dipstick "popping" itself loose on startup? This has happened to me a couple times now and if I don't check under the hood frequently, I'll find an engine sprayed with oil. Let me know your thoughts on this issue. Link to comment Share on other sites More sharing options...
the underlørd Posted March 22, 2006 Report Share Posted March 22, 2006 sounds like a PCV problem maybe? Link to comment Share on other sites More sharing options...
BlackBeast Posted March 22, 2006 Report Share Posted March 22, 2006 sounds like a PCV problem maybe?Yep, excessive crankcase pressure usually pops the dipstick out. Link to comment Share on other sites More sharing options...
red c70 Posted March 22, 2006 Author Report Share Posted March 22, 2006 Yep, excessive crankcase pressure usually pops the dipstick out.And how can I solve this problem...fatter o-ring on the dipstick or more complicated than that? Link to comment Share on other sites More sharing options...
the underlørd Posted March 22, 2006 Report Share Posted March 22, 2006 And how can I solve this problem...fatter o-ring on the dipstick or more complicated than that?fix the PCV system... check http://volvospeed.com/vs_forum/index.php?showtopic=29650 there, that's for a 850, but you'll get the general idea.but a new oring wouldn't be a bad idea to start with. Link to comment Share on other sites More sharing options...
Volvo Virgin Posted March 23, 2006 Report Share Posted March 23, 2006 fix the PCV system... check http://volvospeed.com/vs_forum/index.php?showtopic=29650 there, that's for a 850, but you'll get the general idea.but a new oring wouldn't be a bad idea to start with.+1 !! And if you are noticing any rust on the dipstick this would also be indicative of a PCV system that needs a good cleaning.The banjo fitting under the intake and the smallest of the 3 lines that lead from it are usually the problem areas.You will probably have to remove the intake to do it unless you're double-jointed and really talented with a nice set of small ratchets.Good Luck! :) Link to comment Share on other sites More sharing options...
Guest AlvinL Posted March 26, 2006 Report Share Posted March 26, 2006 Hey, at least popping out dipstick is better than popping out the RMS! :lol: Link to comment Share on other sites More sharing options...
