slarti Posted March 27, 2006 Report Share Posted March 27, 2006 Im having a problem with my remotes. I have changed the batteries in both remotes, checked all the fuses and Ive tried to reprogram the remotes. (5 times on and off then push buttons on the remote. Ive had no luck. Any suggestions would be appreciated.Also, the keyhole on my truck lid doesnt turn. Link to comment Share on other sites More sharing options...
slarti Posted March 30, 2006 Author Report Share Posted March 30, 2006 Anyone? Thanks Link to comment Share on other sites More sharing options...
crc1185 Posted March 30, 2006 Report Share Posted March 30, 2006 I have the same problem... I think the actual remote module in the car is shot. I haven't felt like dealing with it, so I just use my keys. Link to comment Share on other sites More sharing options...
850-Turbo Posted March 30, 2006 Report Share Posted March 30, 2006 Im having a problem with my remotes. I have changed the batteries in both remotes, checked all the fuses and Ive tried to reprogram the remotes. (5 times on and off then push buttons on the remote. Ive had no luck. Any suggestions would be appreciated.Also, the keyhole on my truck lid doesnt turn. Is the trunk lid in locked state or unlocked state? I have an intermittant problem with the remote not working and a lot of times, I find the rear hatch to be unlocked. That's after locking with the remote and all the doors locked except for the hatch.Also, when this happens, the alarm won't be armed. The LED won't flash. Just something to check. Link to comment Share on other sites More sharing options...
Guest AlvinL Posted March 30, 2006 Report Share Posted March 30, 2006 That's right. There are microswitches in the door and trunk latches that checks that they're all in the same direction (lock or unlock). If they're not in the same direction due to a broken latch motor or the microswitches are defective, the remote won't work.Try manually locking them then use the remote to open. If that doesn't work, manually unlock them then try remote to lock. This should help you narrow down which latch is the problem.If still doesn't work, perhaps something else is wrong. Link to comment Share on other sites More sharing options...
slarti Posted March 31, 2006 Author Report Share Posted March 31, 2006 The trunk lid locks and unlocks with the rest of the doors, however when I put the key in the trunk lid I cant turn it.When I lock the car with the keys the led on the dash does flash. I have tried the remote several times with no success. Link to comment Share on other sites More sharing options...
