erk1983 Posted April 1, 2006 Report Share Posted April 1, 2006 well i got the transmission serviced today and on my way home the cel came on which lately isnt surprising , but as i was leaving my girlfriends house i noticed that my abs and traction lights are on also..i hate this crap what could be some possibilities? i know that i will check the fluid in the master cylinder but other than that what are these lights brought on for? Link to comment Share on other sites More sharing options...
Gregg Posted April 1, 2006 Report Share Posted April 1, 2006 sometimes my abs/tracs lights come on for no reason. If I pull over, turn off the car, and restart, the lights normally go away. I think this is the sign of a fading abs/tracs module? Link to comment Share on other sites More sharing options...
Plan_B Posted April 1, 2006 Report Share Posted April 1, 2006 could also be either the ignition or the shifter. Link to comment Share on other sites More sharing options...
Zappo Posted April 1, 2006 Report Share Posted April 1, 2006 sometimes my abs/tracs lights come on for no reason. If I pull over, turn off the car, and restart, the lights normally go away. I think this is the sign of a fading abs/tracs module? You are right, that is exactly what it is. I had that same problem for some time. Turn it off and back on, and the lights are out, but come back after a while. I lived with it for months, then finally replaced the control module and the problem was gone.i hate this crap what could be some possibilities? i know that i will check the fluid in the master cylinder but other than that what are these lights brought on for? The lights come on indicating that traction control and ABS are offline, so to speak. It just means they are no longer working, but you can drive the car just fine. Like Gregg said, if you turn the ignition off and back on, they will probably go away, but it is only temporary. You will most likely have to replace the control module, or have yours repaired. You can drive the car just fine the way it is. The CEL you are getting is probably not related, so you will need to check that to see what it is. Link to comment Share on other sites More sharing options...
Karlson Posted April 1, 2006 Report Share Posted April 1, 2006 Erik, did u ever sent your module to guy in california?Trac/off and abs is one module I did mine two years ago, here is the link http://home.earthlink.net/~vicrocha/Volvo_...lvo_V70_ABS.htmabout cel, darn! we talked about that on Wednesday and u got it today. I am pretty sure you will get 2 codes right now, one for o2 sensor and another one for cat..and don't hate your carI think majority of people on this board had the same problem as you do right now Link to comment Share on other sites More sharing options...
Deuss Posted April 1, 2006 Report Share Posted April 1, 2006 Yep same thing my cel light is on after tranny exchange.. its O2 sensor. DOnt hate it just take a b-ball bat and smash it to pieces and claim insurance on it. Im joking. All I can say is GL to you! Cuz you me and many others need it to fix the O2 problem.. GRRRRRRR :ph34r: Link to comment Share on other sites More sharing options...
jays850 Posted April 1, 2006 Report Share Posted April 1, 2006 B)-->QUOTE(Plan B @ Apr 1 2006, 05:47 AM) ←could also be either the ignition or the shifter.Exactly what my car was doing. After starting the car the ignition switch wasn't springing back so I just turned it back alittle and all these lights dissapear. So next time there on try messing with your ignition switch alittle.Jay Link to comment Share on other sites More sharing options...
