asamaan Posted April 1, 2006 Report Share Posted April 1, 2006 Well, I think the engine is done. Radiator been broken for a while after an accident and she kept driving it, overheated it a couple of times. Finally got the radiator fixed and it seems that there is a lot of pressure in the cooling system. On top of that the oil on the dipstick looks like mud. No smoke off the back. Noticed smoke from the filler bottle on start, even when cold. I am guessing the head gasket is done, am I correct?Albert95 850 Auto Link to comment Share on other sites More sharing options...
850-Turbo Posted April 1, 2006 Report Share Posted April 1, 2006 Well, I think the engine is done. Radiator been broken for a while after an accident and she kept driving it, overheated it a couple of times. Finally got the radiator fixed and it seems that there is a lot of pressure in the cooling system. On top of that the oil on the dipstick looks like mud. No smoke off the back. Noticed smoke from the filler bottle on start, even when cold. I am guessing the head gasket is done, am I correct?Albert95 850 Auto Most likely. Just hope it's not a cracked head. :o Link to comment Share on other sites More sharing options...
Guest Guest Posted April 1, 2006 Report Share Posted April 1, 2006 Thanks, I guess it's time to look for another car.Albert Link to comment Share on other sites More sharing options...
MikeH Posted April 2, 2006 Report Share Posted April 2, 2006 Well, I think the engine is done. Radiator been broken for a while after an accident and she kept driving it, overheated it a couple of times. Finally got the radiator fixed and it seems that there is a lot of pressure in the cooling system. On top of that the oil on the dipstick looks like mud. No smoke off the back. Noticed smoke from the filler bottle on start, even when cold. I am guessing the head gasket is done, am I correct?Albert95 850 AutoWhen I flushed out cooling system last year I was getting that too. It was like the coolant was boiling and stuff. I was abit conserned. I kept taking the cap off to relieve it (car somewhat cooled down before taking cap off - letting out alot of air) It went away after a week or so. So I think it was just excess air or something in the system and it was purging it out. Link to comment Share on other sites More sharing options...
850-Turbo Posted April 2, 2006 Report Share Posted April 2, 2006 When I flushed out cooling system last year I was getting that too. It was like the coolant was boiling and stuff. I was abit conserned. I kept taking the cap off to relieve it (car somewhat cooled down before taking cap off - letting out alot of air) It went away after a week or so. So I think it was just excess air or something in the system and it was purging it out. Interesting! In the old days, flushing the cooling system, especially with the chemical flush, the radiator and freeze plug sometimes leaked due to unclogging the the rust that was sealing the leaks. I wonder that was the case for you, Mike? And after a while, the head gasket leak got sealed up again. The engine shouldn't have "excess" air. That just means you were low on coolant, giving you more air space, which you would have noticed as you would have needed to refill the radiator right away. I wonder if it would come back if you flush it again. :huh: Link to comment Share on other sites More sharing options...
