mikie Posted April 4, 2006 Report Share Posted April 4, 2006 So engine lights on again, PO172 (Mass air metering system...), and PO1003( running too rich bank 1). Same numbers like before if I recall. Seems like it's my MAF right? So I was wondering once a new maf (which should be free cause I believe I have a year warrenty) is installed does volvo have to download any softwear??? Basically can I just get the parts, install them myself and then just erase the codes right?Thanks Link to comment Share on other sites More sharing options...
mikeys Posted April 5, 2006 Report Share Posted April 5, 2006 So engine lights on again, PO172 (Mass air metering system...), and PO1003( running too rich bank 1). Same numbers like before if I recall. Seems like it's my MAF right? So I was wondering once a new maf (which should be free cause I believe I have a year warrenty) is installed does volvo have to download any softwear??? Basically can I just get the parts, install them myself and then just erase the codes right?ThanksI did on my 98 S70, piece of cake, it only has two bolts that hold it on. They told me just to be sure to unhook the battery for about 15 minutes to allow the ETM to reset with the new MAF. Link to comment Share on other sites More sharing options...
mikie Posted April 5, 2006 Author Report Share Posted April 5, 2006 I did on my 98 S70, piece of cake, it only has two bolts that hold it on. They told me just to be sure to unhook the battery for about 15 minutes to allow the ETM to reset with the new MAF.Perfect thanks Link to comment Share on other sites More sharing options...
turbomolar Posted April 7, 2006 Report Share Posted April 7, 2006 Does unhooking the battery for 15 mins effect an IPD flashed chip?DOes disconnecting the battery do the same thing as resetting the CEL with an OBDII scanner? Link to comment Share on other sites More sharing options...
the underlørd Posted April 7, 2006 Report Share Posted April 7, 2006 Does unhooking the battery for 15 mins effect an IPD flashed chip?DOes disconnecting the battery do the same thing as resetting the CEL with an OBDII scanner?NO.Just take out the ECU for 15 minutes. Link to comment Share on other sites More sharing options...
mikie Posted April 8, 2006 Author Report Share Posted April 8, 2006 NO.Just take out the ECU for 15 minutes.But for someone with an OBDII scanner, no need to remove the ECU or battery for 15 minutes right? Link to comment Share on other sites More sharing options...
