CRK Posted April 17, 2006 Report Share Posted April 17, 2006 Please select how much and post what ECU you use, and what mods you run to get it there.Stock 855-t with only a INMotion ECU running around 10~13 psi then a small spike to 15 psi at gear change. I need to finish my stage 0 and retest, I know I have leak. Link to comment Share on other sites More sharing options...
Guest S7013g Posted April 17, 2006 Report Share Posted April 17, 2006 Stock S70 awd, SpeedTuning USA ecu set @ 12PSI, with spikes to 15PSI. Link to comment Share on other sites More sharing options...
POOKDIZZLE Posted April 17, 2006 Report Share Posted April 17, 2006 Running around 14psi with spike of @ 16.5psi. Link to comment Share on other sites More sharing options...
the underlørd Posted April 17, 2006 Report Share Posted April 17, 2006 131.0004 KilopascalsMTE. Link to comment Share on other sites More sharing options...
BlackT5 Posted April 17, 2006 Report Share Posted April 17, 2006 1.3barUpsolute Link to comment Share on other sites More sharing options...
WhiteT5 Posted April 17, 2006 Report Share Posted April 17, 2006 14 PSI stock chip, no boost controller either , frightening b/c my AFR's at WOT also correspond to that number lately . Link to comment Share on other sites More sharing options...
ViperVette Posted April 17, 2006 Report Share Posted April 17, 2006 Stock ECU, 10 PSI... cause that is what stock boost is at. If anyone selects your first two options, they are in boost leak territory. Link to comment Share on other sites More sharing options...
96PlatinumEdition850 Posted April 17, 2006 Report Share Posted April 17, 2006 I'm at like 8-9 PSI with stock 854 T5 but that's what it should be so that wouldn't be a boost leak. Also S70 GLT have between 1-6PSI so that wouldn't be a boost leak either. Am I right? Link to comment Share on other sites More sharing options...
erk1983 Posted April 17, 2006 Report Share Posted April 17, 2006 I'm at like 8-9 PSI with stock 854 T5 but that's what it should be so that wouldn't be a boost leak. Also S70 GLT have between 1-6PSI so that wouldn't be a boost leak either. Am I right?12 psi , spikes to 15-16 .... stock ecu thank you very much Link to comment Share on other sites More sharing options...
spottieottie Posted April 18, 2006 Report Share Posted April 18, 2006 18 psi, stock chip :ed: 18 psi, stock chip :ed: spikes to 19, but is a helluva lotta fun! Link to comment Share on other sites More sharing options...
CHARGER69O1 Posted April 18, 2006 Report Share Posted April 18, 2006 Boom at 31 +, then VMS Motor now I keep it between 25-30 ;) Link to comment Share on other sites More sharing options...
Oreo931 Posted April 18, 2006 Report Share Posted April 18, 2006 NA's dont boost. I have 21 hg in vaccum pressure :) Link to comment Share on other sites More sharing options...
Zulu Posted April 18, 2006 Report Share Posted April 18, 2006 20lbs stock ecu, i dunno. turbo is failing so 11lbs now :D Link to comment Share on other sites More sharing options...
WhiteT5 Posted April 19, 2006 Report Share Posted April 19, 2006 12 psi , spikes to 15-16 .... stock ecu thank you very muchTake that POS flowmaster off and you can make some real boost . Link to comment Share on other sites More sharing options...
maiku Posted April 20, 2006 Report Share Posted April 20, 2006 SpeedTuning17psispikes at 18 M56 powah Link to comment Share on other sites More sharing options...
