Dvk Posted April 24, 2006 Report Share Posted April 24, 2006 I have a 1400 watt amp and is going to be installed in my car..What farad capacitor should i have soo i wont need a new battery or alternator...2 farard-3-5 or 8..Lemme know please Link to comment Share on other sites More sharing options...
the underlørd Posted April 24, 2006 Report Share Posted April 24, 2006 1 farad per every 1000 watts, is what I've read. hth. Link to comment Share on other sites More sharing options...
Owned Posted April 24, 2006 Report Share Posted April 24, 2006 Use a single farad. Link to comment Share on other sites More sharing options...
CAKES855 Posted April 25, 2006 Report Share Posted April 25, 2006 it all depends on what ohm rating you are running the amp at, i would suggest a minimum of a 2 farad cap, i have 2 single farad caps and a 400 watt 4 channel and a 1000 watt mono block running at 1 ohm, with one cap my lights dimmed BAD so i had another so i put it in and it did wonders, i say 2 farad minimum, follow Kevin's words of wisdom Link to comment Share on other sites More sharing options...
Dvk Posted April 25, 2006 Author Report Share Posted April 25, 2006 it all depends on what ohm rating you are running the amp at, i would suggest a minimum of a 2 farad cap, i have 2 single farad caps and a 400 watt 4 channel and a 1000 watt mono block running at 1 ohm, with one cap my lights dimmed BAD so i had another so i put it in and it did wonders, i say 2 farad minimum, follow Kevin's words of wisdomAlright im going to try a 1 farad cap..I found a deal on 1600 wat max wiring and a 1 farad cap together soo ill try that and if it doesnt work ill buy a 2 farad Link to comment Share on other sites More sharing options...
Dvk Posted April 25, 2006 Author Report Share Posted April 25, 2006 Alright im going to try a 1 farad cap..I found a deal on 1600 wat max wiring and a 1 farad cap together soo ill try that and if it doesnt work ill buy a 2 faradAlright i came across a 1/2 farad cap for free...you think that will do anything or at least stop the dimming a lil..I dont care if it dims just a little but if a 1/2 it will still be bad should i get the 1? Link to comment Share on other sites More sharing options...
Owned Posted April 25, 2006 Report Share Posted April 25, 2006 Alright i came across a 1/2 farad cap for free...you think that will do anything or at least stop the dimming a lil..I dont care if it dims just a little but if a 1/2 it will still be bad should i get the 1?Get the wiring kit and single farad. Link to comment Share on other sites More sharing options...
Owned Posted April 25, 2006 Report Share Posted April 25, 2006 it all depends on what ohm rating you are running the amp at, i would suggest a minimum of a 2 farad cap, i have 2 single farad caps and a 400 watt 4 channel and a 1000 watt mono block running at 1 ohm, with one cap my lights dimmed BAD so i had another so i put it in and it did wonders, i say 2 farad minimum, follow Kevin's words of wisdomYou're contradicting yourself here. If he were to follow the rule of thumb, and it's exactly that, which Kevin posted, a 1 farad would be the out come. He posted "1400 watts" and did not mention if it's RMS or not. This means there's a high probability that he does not know the difference between RMS and peak/max/whatever. I'm not faulting him for this at all. However, knowing that it's probably his amp's peak, we can assume that the RMS is going to be half, or 750 RMS, leading us to a single farad.Could he run a 2F cap with no problems? Absolutely. He can run a 40F cap if he wants to. But a single should be good enough, assuming everything else that factors into the equation is in good working order. Link to comment Share on other sites More sharing options...
R_rated Posted April 25, 2006 Report Share Posted April 25, 2006 way to many variables to consider. You shouls be fine with a single 1 farad and stock battery but it really depends on the effinciency of the amp and the power supply. Link to comment Share on other sites More sharing options...
