8G5L0T Posted May 3, 2006 Report Share Posted May 3, 2006 Hey is do you guys know of anything i can do that will make the temperature that appears on the trip computer be correct. The temperatures i get tend to be 20-30 degrees off. Can a sensor or something be dirty, causing the bad reading? Thanks Link to comment Share on other sites More sharing options...
javadoc Posted May 3, 2006 Report Share Posted May 3, 2006 Hey is do you guys know of anything i can do that will make the tempurature that appears on the trip computer be correct. The tempuraters i get are 20-30 degrees off. Can a sensor or something be dirty, causing the bad reading? ThanksSitting in traffic, mine will go up by maybe 20F. Are you constantly getting erroneous readings? Link to comment Share on other sites More sharing options...
the underlørd Posted May 3, 2006 Report Share Posted May 3, 2006 are they plugged into their correct locations? Link to comment Share on other sites More sharing options...
8G5L0T Posted May 3, 2006 Author Report Share Posted May 3, 2006 My readings are always off. Some times in the morning it says its 90 degrees. Hey Kevin, where do i check to make sure they are plugged in the correctly? Another question how hard is it to replace the front CV Joints. Link to comment Share on other sites More sharing options...
the underlørd Posted May 3, 2006 Report Share Posted May 3, 2006 My readings are always off. Some times in the morning it says its 90 degrees. Hey Kevin, where do i check to make sure they are plugged in the correctly? Another question how hard is it to replace the front CV Joints.Thre's one on the passenger side of the splash gaurd, and one of the drivers side bumper trim peice.(this is 70 series, but i bet it's close on 850's) Link to comment Share on other sites More sharing options...
