RussB Posted May 10, 2006 Report Share Posted May 10, 2006 lotta local guys here... B) Link to comment Share on other sites More sharing options...
prasamin Posted May 10, 2006 Report Share Posted May 10, 2006 under $400 for your RMS is a deal man. Link to comment Share on other sites More sharing options...
RWagin Posted May 10, 2006 Author Report Share Posted May 10, 2006 One of the reasons I bought this car was because I knew I had a great mechanic to work on it. He was a master tech at a Volvo dealership I worked at when I was in college. I used to hang out with him when the sales department was slow.edit: Someone asked if I was thinking about selling, I would say I would consider it, Travis pm'd me earlier today asking the same question, "for s & g's" I really want a manual transmission. Link to comment Share on other sites More sharing options...
Stamperman Posted May 10, 2006 Report Share Posted May 10, 2006 Saturday I am changing the Rear main seal on my car (I am not doing it but a Volvo Tech I know is) is there anything else that I should have done while this is being done, I know the flame trap would be done if it was an N/A. Car is pretty solid and the RMS leak is very minor but want to take care of it before it effeects any O2 sensors.It's a very oppurtune time (while the subframe is hanging there) to change the front and rear hydraulic motor mounts. Like others have said, input shaft seal on the trans, halfshaft seals. I pulled the motor and trans out of top when I did mine, so I replaced the timing belt, turbo oil line gaskets and vacuum lines while it was out. I bet the volvo tech you have doing just drops the subframe and pulls trans out from the bottom. Link to comment Share on other sites More sharing options...
r850glt Posted May 10, 2006 Report Share Posted May 10, 2006 Torque Convertor seal Link to comment Share on other sites More sharing options...
RWagin Posted May 10, 2006 Author Report Share Posted May 10, 2006 It's a very oppurtune time (while the subframe is hanging there) to change the front and rear hydraulic motor mounts. Like others have said, input shaft seal on the trans, halfshaft seals. I pulled the motor and trans out of top when I did mine, so I replaced the timing belt, turbo oil line gaskets and vacuum lines while it was out. I bet the volvo tech you have doing just drops the subframe and pulls trans out from the bottom.Correct, dropped the subframe and pulled the tranny from the bottom. Link to comment Share on other sites More sharing options...
v70XXXc Posted May 10, 2006 Report Share Posted May 10, 2006 wow thats the second sub $400 RMS job i have seen here in the last month. I didn't know any mechanic worked for $20/hr anymore. my cleaning lady is $75/hr .a dealer quoted me $1150 w/ $250 in parts alone and an indy quoted me $750 including parts, but now that i know there is a better deal out there, i will keep searching. Link to comment Share on other sites More sharing options...
