rodrigo Posted May 7, 2006 Report Share Posted May 7, 2006 I looked in Bay13 write up for vaccuum leaks and compared it to my car (2000 LPT) and things look a bit different as far as the elbow locations...at least they seem to be different. My intake manifold is different than the regular 98 and < manifold, and my car has ETM. I was havong a hard time locating the elbow by the power steering pump as described on Bay 13, and any other elbows for that matter...I got the elbow kit from IPD and was oping to do it today...any suggestions/locations/pics of these things??TIA R Link to comment Share on other sites More sharing options...
rodrigo Posted May 7, 2006 Author Report Share Posted May 7, 2006 pleeeeeeeeeeze....... Link to comment Share on other sites More sharing options...
Johann Posted May 7, 2006 Report Share Posted May 7, 2006 There's no elbow.. Has been changed to a banjo style connection underneath de manifold and also close to the powersteering pump.It shouldn't bring the problems the old elbow did.There are only 4 vacuum connections to the manifold. One is the big brake booster hose, a smaller hose on the engine side of the plenum cylinder no. 5 for the recirculation valve, there is a connection of the crank ventilation in the middle of the round collector above the throttle body and the earlier mentioned crank vent banjo connection. Link to comment Share on other sites More sharing options...
Johann Posted May 7, 2006 Report Share Posted May 7, 2006 Link to comment Share on other sites More sharing options...
rodrigo Posted May 7, 2006 Author Report Share Posted May 7, 2006 Wow...thanks for the help Johann. Im going to have yet another look.So, there are no elbows on these...just the hose and spring clip to keep it in place? is the banjo fitting the little clamp on the ends of the hoses? Link to comment Share on other sites More sharing options...
Johann Posted May 7, 2006 Report Share Posted May 7, 2006 Wow...thanks for the help Johann. Im going to have yet another look.So, there are no elbows on these...just the hose and spring clip to keep it in place? is the banjo fitting the little clamp on the ends of the hoses?See if I can make a picture tomorrow of the banjo piece.It's almost bedtime for me plus I don't have the parts near me.. ;) Link to comment Share on other sites More sharing options...
rodrigo Posted May 7, 2006 Author Report Share Posted May 7, 2006 Johann...thanks a lot for your help :) Link to comment Share on other sites More sharing options...
PorBleemo Posted May 8, 2006 Report Share Posted May 8, 2006 Is that intake manifold more efficient then the one found on the 850s? Link to comment Share on other sites More sharing options...
Johann Posted May 8, 2006 Report Share Posted May 8, 2006 Wow...thanks for the help Johann. Im going to have yet another look.So, there are no elbows on these...just the hose and spring clip to keep it in place? is the banjo fitting the little clamp on the ends of the hoses?The manifold and headhave better flow compared to the older models. Link to comment Share on other sites More sharing options...
rodrigo Posted May 8, 2006 Author Report Share Posted May 8, 2006 Thanks Johann.So the banjo connections is like the CIS fuel fitting on older VW's...cool!So, now, are there any elbows on the car anywhere or is it all liek that...i was looking around and removed the air intake tube to the filter box, and was snooping around, and tried looking but I didn't find any anywhere. under the airbox maybe?? :huh: Link to comment Share on other sites More sharing options...
Johann Posted May 8, 2006 Report Share Posted May 8, 2006 The knee like on the back of the older 850 manifold isn't used on the newer engine's. Link to comment Share on other sites More sharing options...
rodrigo Posted May 8, 2006 Author Report Share Posted May 8, 2006 thanks a lot for your help Johann :) Link to comment Share on other sites More sharing options...
BtownVolvo Posted May 8, 2006 Report Share Posted May 8, 2006 So where would be a good place to T-in for a boost gauge?Awesome info BTW...this should be pinned!!! Link to comment Share on other sites More sharing options...
Johann Posted May 8, 2006 Report Share Posted May 8, 2006 So where would be a good place to T-in for a boost gauge?First picture CBV connection. Link to comment Share on other sites More sharing options...
BtownVolvo Posted May 9, 2006 Report Share Posted May 9, 2006 First picture CBV connection.That's what i was thinking Thanks Johann! Link to comment Share on other sites More sharing options...
